20 Most Recent Simplicity Fashion Pro SW2145 Mechanical Sewing Machine Questions & Answers
How I can get download of Simplicity Fashion Pro SW2145 Manual for free ? How to adjust the length of feet to make it wider on above machine ?
Search the internet for: Manufacturer + Model + the word "Manual" ...
11/5/2015 6:42:51 PM • Simplicity... • Answered on Nov 05, 2015
How do i thread the bobbin on simplicity fashion pro sw 2145
normally counter clock wise for bobbin, usually the first thread holder is used and the 2nd is used for double needles. here is a link for parts Simplicity SW2145 Parts
12/8/2014 5:48:53 PM • Simplicity... • Answered on Dec 08, 2014
What dial position due I need for straight stitch. All I can get is decorative stitches
I can't find a clear image of the machine dials - if you can add a photo that would help. There must be a neutral position for the dial or a button somewhere to switch off the decorative stitches. Try turning the dial to the section without any stitches marked.
9/14/2014 5:35:33 AM • Simplicity... • Answered on Sep 14, 2014
Turn on maching and it automatically is going without foot on peddle
could possibly have a short somewhere, it would be a good idea to have it checked.
5/2/2014 7:28:31 PM • Simplicity... • Answered on May 02, 2014
Maching starts without using foot peddle
"Ghost sewing" sometimes occurs when the wires inside the foot are making contact before the pedal is even used. There is sometimes a "dial" on the bottom of the foot pedal (usually accessed through a small hole with a miniature flat bit screw driver) that can be fine tuned for responsiveness. If the dial is labeled + or -, turn the dial toward the minus to reduce the responsiveness of the pedal, (should be counterclockwise) and if it is not labeled just try quarter turns until the pedal operates as is should. If there is no adjustment, you may have to open and repair or replace the pedal.
4/10/2014 1:52:02 AM • Simplicity... • Answered on Apr 10, 2014
I would like to know which foot attachment you use on stretch fabric
You would normally use your standard sewing foot, or usually called your "zig-zag foot" for sewing on stretch fabric, just as you would woven fabric. Or, you can buy a "walking foot" sometimes called an "even feed" foot that will help the top and bottom layers to feed more evenly together. If your model has an adjustable presser foot tension, (adjusts the "drop" strength of your foot that you will feel when you raise and lower the presser foot lever) you may want to decrease it some, and test a scrap to see how well it feeds the particular fabric you want to use. You can also use an "over-edge foot" with certain utility stitches to give a 1/4 inch seam that looks similar to a serged seam. You may want to find a book (I like to borrow them from my library) that shows various sewing machine feet and what they can be used for. Don't forget to use ball point sewing machine needles for stretch fabrics. Good luck with your project!
1/15/2014 6:05:06 AM • Simplicity... • Answered on Jan 15, 2014
0answers
0answers
Sw2145 manual
Be the first to answer 11/25/2013 4:30:25 AM • Simplicity... • Posted on Nov 25, 2013Be the first to answer
0answers
Tension problems
Be the first to answer 11/18/2013 8:03:09 PM • Simplicity... • Posted on Nov 18, 2013Be the first to answer
0answers
Model 640 manual
Be the first to answer 10/12/2013 3:30:56 AM • Simplicity... • Posted on Oct 12, 2013Be the first to answer
Speed
R Whitney, actually, I'm not the sewing machine expert. My husband does sewing machine repairs. So, I had him read your problem and he said, that what your machine needs, is to be taken to a shop. They haveto clean all of the old oil off of it and reoil it. It's a service that everymachine needs at least once a year. It happens because of the dust and lint that gathers in the oil. It can't be helped. It just happens, but when you get it back it should run like a new machine. They'll oil it and readjust everything. You'll love the way it sews after they finish it.
10/2/2012 9:46:22 PM • Simplicity... • Answered on Oct 02, 2012
Stiches are not sewing straight - will go straight for several stitches & then
it says go straight fo rseveral stitches & then? need more information
3/2/2012 1:25:53 AM • Simplicity... • Answered on Mar 02, 2012
How do I obtain a manual for the Simplicity Fashion Pro Sewing Machine, model #SW2145
jam in the bobben arera
11/20/2011 12:01:54 AM • Simplicity... • Answered on Nov 20, 2011
How do i get a
Set "Stitch Width" dial on top of the machine to 0 (Zero). JLP
11/12/2011 7:20:06 PM • Simplicity... • Answered on Nov 12, 2011
Simplicity Fashion Pro SW2145 Mechanical Sewing Machine Logo
67 questions posted
Top Simplicity Sewing Machines Experts
vince
NOEL
NOEL
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Simplicity Sewing Machines
Most Popular Question
thread bobbin simplicity fashion pro sw
  • Sewing Machines
