20 Most Recent
Singer 5062 Mechanical Sewing Machine Questions & Answers
Presser foot lever stuck
You lever doesn't work because the presser foot Bar is seized from lack of use.Open the side of the machine to access the bar. Put a mixture of water and ammonia ( about 80%water 20% ammonia) on the top and bottom of the bar. Let it sit for 15-20 minutes then try to move the presser foot Up by lifting the foot with a screw driver. Do not pry so hard you break something. It should get progressively easy the more times you do this. Put some sewing machine oil on the top and bottom of the shaft and it should be good to go.
sewman7
Birds nest under fabric
try a new needle
always keep a check on the thread take up lever, because sometimes the thread will come off & it can jam the machine up
clean under the needle plate for lint or loose thread & also the bobbin area
always check to make sure you have the correct needle for the fabric your sewing
The bobbin will not wind
Mine did same thing,was told to wrap twice around the silver know where you normally wrap twice,make sure bobbin is all the way down.dont forget you start threading as if you were going to for top thread go thru first hook then over to silver know,but twice.hope this helps did me
