20 Most Recent Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack Questions & Answers
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
Cobra Microtalk... | Answered on Aug 26, 2019
Probably time to trash and purchase new.
Try Cobra tech support directly here: Support Cobra Electronics Corporation
Cobra Microtalk... | Answered on Feb 04, 2018
Fuzzy Wuzzy was a Bear,
Fuzzy Wuzzy had no hair
If Fuzzy Wuzzy had no hair,
then Fuzzy Wuzzy wasn't very Fuzzy,
Was He?
Contact Cobra support here: Support Cobra Electronics Corporation
Cobra Microtalk... | Answered on Feb 02, 2018
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Cobra Microtalk... | Answered on Dec 13, 2017
The monitor function is turned on, on the unit that is noisy.
The manual describes the procedure for setting the monitor function the manual is available here.
https://www.cobra.com/support/product-manuals
Cobra Microtalk... | Answered on Sep 03, 2015
press & hold "mode" then use the channel up & down button until you hear it, depress the PTT to return to normal
Cobra Microtalk... | Answered on Feb 11, 2015
fyi my Cobra microTALK LI7500-WX came out of the box with one of the radios slightly off frequency, limiting range to about 100 ft. I was able to use a counter to fix it. The freq adjust is under the front faceplate that covers and protects the LCD screen, pry it off to expose one tuning pot.
Cobra Microtalk... | Answered on Dec 25, 2014
If the antenna is exposed that radio will get inductance, normally most walkie talkie antennas are
composed of a coil of bare wire, a shield around the wire to keep out inductance or noise, and
the outer layer to keep it together and protected. if the metal is exposed you can cover the area
with a piece of aluminum foil and wrap it with black tape or electrical rubber tape sold at most
hardware stores or an electrical supplier. or you can go and by another antenna. good luck!
Cobra Microtalk... | Answered on Dec 12, 2014
It's because the designers thought you wouldn't trust that the battery saver function if it didn't flash or otherwise tell you it's working, I think it's directed toward the small child market.
There are three functions on that unit that cause some kind of beep.
one in the tone when you first turn telling you it's working.
Then there is the one that cobra refers to as the 'Talk Confirmation Tone' telling the other person it's ok to talk.
The third will only be sent if you do it intentionally, that's the call alert tone.
You have absolutely no way to disable those first two functions as they are hard coded into the handheld memory.
These are made to be ......... proof and are just a marginal step forward in technology from the tin cans and string.
Cobra Microtalk... | Answered on Dec 11, 2014
Radio shack sells "splitters" that have 2 cigarette lighter outlets with one plug. About your only option.
Cobra Microtalk... | Answered on May 04, 2014
Radio Communications Logo
115 questions posted
Top Cobra Radio Communications Experts
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
cobra pr 3850wx bought new nimh 800mah
  • Radio Communications
