Samsung Galaxy S4: Rent A Center Disable Locked it: Need 4 digit code to unlock:
Hello. The unlock code you need is specific to that phone. The only way to get the pin to unlock is from RAC. They have remote locked it. The files for this remote lock are hidden and embedded within the firmware. So, even if you factory reset and wipe the dalvik cache, it will still be locked.
From what I understand.. as time goes by, the debt you owe will be transferred to a Debt Collector and your credit will suffer from the derogatory for seven years
If you really want to use this phone.. There is a way.. You will not be able to use the Samsung firmware software that runs on the phone any more.. but you can wipe all data on it, and put on another ROM firmware, but it will be virgin Android. Meaning basic Android phone options.. See the attached link for instructions to do this:
Reference Link:
rent center locked galaxy s5
Do you have a case on your phone? Aluminum cases will reduce signal. What about a tin roof on your house. That can affect it if you are far from a tower. Some models of phones have also had defects causing that. Warranty would cover it.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Free Data Recovery Software-GT Recovery for Android!
Facebook:http://www.facebook.com/GT-Recovery-16556868313%C2%AD68830
Download Link: http://www.gtrecovery.net/
Connecting to a Wi-Fi network does not means you will get an Internet connection. That all depends how the Wi-Fi router is attached to the true network by Ethernet, DSL (phoneline), or cable modem.You must contact the network owner or administrator to confim why you cannot get an Internet connection even if the Wi-Fi connection is strong.
Te best way is to install a Micro SD car in the S4 phone, then use "My Files" app to locate and copy the files from the memory to the SD card. Then remove the SD card and move it to the tablet.
Try connecting a wired headphone to the jack and make a new call. If you can hear the other person, yhe internal speaker may be bad. Keep using the wired headphone, or use a Bluetooth headphone until you decide to upgrade the phone. I recommend the S6 or S8 (the even number model are better).
Try to power it on while the charging cable is attached. If it does, then the cell or the charging circuit may be bad. If i does not power on, try a different Micro USB cable and/or charger, too.
Feb 5, 2014 - Did you forget the pattern to unlock your Samsung Galaxy S4smartphone? ... you unlock and bypass the pattern lock screen security even if youhave ... After about 5 incorrectly drawn patterns it will lock you out and tell you to ....It's been more than a month already that I've been trying to find a solution for it.
Feb 13, 2014 - Do you feel foolish because you locked yourself out of your phone? Learn how to ... I've tried it and every # combination I could think of. Nothing ... I have a question- I accidentally locked my Samsung Galaxy S4. I know my pin ...
Go to contacts and then to the contact that you want to unblock. when that contact is opened on the screen go to top right/left corner and press a 3 dots symbol and then select unblock contact.
Accidently deleted some contacts on your Samsung ? A simple app from play store can help you from big headache of Restoring deleted Contacts.
Here on video we Show you step-by-step guide to recover deleted contacts on android device.
With this way you can recover deleted contacts on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
I would say yes there are a number of data recovery programs available which can do this for you but you have be real quick with the recovering process, because further delay means that place where your data previously was gets over written by something else. You can use software to recover you data back. But do remember act fast over it and don't try writing something more over it otherwise the chances of getting your things back will decrease.
MobiKin Doctor for Android Windows VersionRecover Deleted Contacts from Android
