20 Most Recent Bulova 96E03 Watch Questions & Answers
0answers
How long should a bulova watch work ---my husband
I would expect the battery to last more like 3 years than three weeks. Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery? I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced. Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
10/17/2017 1:02:28 AM • Bulova Diamond... • Answered on Oct 17, 2017
What battery fits bulova 96r000 watch
pop the back off and look, battery should have a number on it.
9/7/2014 5:06:51 PM • Bulova Diamond... • Answered on Sep 07, 2014
Whats the value of bulova watch c9671206 ?
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
8/6/2014 9:54:44 AM • Bulova Diamond... • Answered on Aug 06, 2014
Animal jam diamond code
Under watches? No not here...
7/25/2014 1:17:18 PM • Bulova Diamond... • Answered on Jul 25, 2014
How to unclasp my watch
You're trying to open the watch, not your fingers. If it is stubborn and you are worried about a possible mishap, take it to Wal-Mart instead.
1/23/2013 2:11:07 AM • Bulova Diamond... • Answered on Jan 23, 2013
What is this watch model Caravelle By Bulova c875182 45C04 and 05
Click on the link and ID your watch. The numbers are not identified. If you bought it on eBay, Amazon or anywhere other than a dealer shop, it is a Chinese clone. They make up model numbers for effect and to avoid litigation. https://www.google.com/search?q=Caravelle+By+Bulova+c875182&sca_esv=584988440&rlz=1C1QJDB_enCA643CA644&tbm=isch&sxsrf=AM9HkKkYbdvYgLAR8s9CmNaospXMuyRW9A:1700802670780&source=lnms&sa=X&ved=2ahUKEwjpjJnY79uCAxUGhYkEHbyDDL4Q_AUoAnoECAQQBA&biw=1920&bih=931&dpr=1 ..
11/24/2023 5:14:13 AM • Bulova Watches • Answered on Nov 24, 2023
How do I change battery for bulova b0553 mini grandfather clock?
Locate the battery: Check the back or bottom of the clock for the door. Open the compartment: Use a screwdriver or your fingers to open the compartment door. Remove the old battery: Remove the old battery and dispose of it properly
10/16/2023 5:09:00 AM • Bulova Watches • Answered on Oct 16, 2023
Bulova 98H48. What battery is in it please? I opened the watch up to replace the battery and ended up losing it. Thanks.
They use many, so the answer is always "the same as the one that came out of it". https://www.energizer.com/specialty-battery-finder/bulova-watch-battery-replacement Nothing here, which is odd because that normally works, https://www.google.com/search?q=Bulova+98H48+battery+type Look for tiny engraving next to the battery compartment. Or ask them direct. https://www.bulova.com/ca/en/contact-us.html ..
3/17/2023 1:19:25 AM • Bulova Watches • Answered on Mar 17, 2023
The push button function on swiss model 2423.11 bulova accutron.
Jesus I can't believe no one answered this guy with even an "I don't know." in 6 years. If it's like my watch, it's for synchronizing the second hand. If you press the button on the minute mark from the NIST time web site, when your watch is ten seconds fast, the second hand will stop for ten seconds. This makes your watch match the time clock. The really cool thing is if your watch is SLOW, if you press the button on the minute mark when your watch is twenty seconds behind the NIST time web site, the second hand will SPEED UP until it matches the NIST time. Very cool and this is **totally from my memory** because I just got my watch back from Bulova but I forgot to ask about the button.
1/1/2022 5:02:13 AM • Bulova Watches • Answered on Jan 01, 2022
How to set a Bulova maritime watch
https://www.bulova.com/pages/manuals-parts
User Manuals
Please consult the user manual that was packaged with your Bulova watch. If you don't have your Bulova user manual, please view our STANDARD MANUAL to read general information about how to set and maintain your watch. You may also view or download a manual/PDF with information specific to your watch. Find the style number on the back of your watch case, then simply click on search icon at the top right, type in the style number, and we'll find it immediately. For all other inquiries or assistance, please contact [email protected] or call 800-233-3350. Parts Manuals
9/30/2021 6:04:01 AM • Bulova Watches • Answered on Sep 30, 2021
What battery does the Bulova C837381 take and how do you put back on?
Tip & How-To about Watches Changing Watch Batteries Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10! Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15! Posted by ADMIN... on Dec 31, 2018
6/14/2021 3:57:55 PM • Bulova Watches • Answered on Jun 14, 2021
NEED A BATTERY FOR BULOVA CL437597
https://www.quora.com/How-do-I-know-which-battery-I-need-to-fix-my-bulova-watch I have changed batteries on watches before but none were bulova. I opened the back which you have to do to change battery find what battery you need and order online. I have been able to find at stores year ago but most watches now days people don't change batteries they buy new watches. It is a little harder to find batteries in stores. When you find the type battery google to get the place to buy it. https://www.energizer.com/specialty-battery-finder/bulova-watch-battery-replacement
8/10/2020 7:11:30 AM • Bulova Watches • Answered on Aug 10, 2020
Bulova 96E03 Watch Logo
4 questions posted
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
View Most Popular
Diamond Bulova
  • Diamond Bulova
Most Popular Question
remove back face replace battery
  • Watches
