20 Most Recent GE WBSR3140DW Top Load Washer Questions & Answers
When the machine is full, the built in sensor triggers a switch to let the machine know there are clothes inside. Check the sensors and/or switch, as they may be faulty.
GE WBSR3140DW... | Answered on Sep 23, 2019
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Lale
GE WBSR3140DW... | Answered on Jun 19, 2019
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
GE WBSR3140DW... | Answered on Mar 25, 2019
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
GE WBSR3140DW... | Answered on Jan 30, 2019
Hi, I don't know the model, but it's possibly moving the water fill nozzle over the Fabric Softener compartment in the soap drawer.
Clicking is normal for that.
GE WBSR3140DW... | Answered on Jan 31, 2018
Sounds like there's a hole or loose ejection water hose.
Move the washer so it will run and you can look in the back to see where the water is coming from....fix the leaky problem once you find it. Could be a bad hose clamp as well
GE WBSR3140DW... | Answered on Dec 12, 2017
Check to see if the tub is free to move in at least one direction or the drain pump for blockage from a small item of clothing. It's best to wash small items in a laundry net bag when mixing with large items to prevent one from getting pushed over the top of the inner tub and either blocking the pump or jamming the tub. Hope this helps you.
GE WBSR3140DW... | Answered on Nov 22, 2017
It sounds like your water system might need some filter housings installed?-- are there any filter housings in any of your water systems?-- If so, what are they accumulating-- what do you find, when you change filters.
Write back what you are finding.. If you have no filters, then let's install either ONE on your common cold water supply to the house-- or start with two at your washing machine. Which would be easier?- Write back-- Mack Baxter
GE WBSR3140DW... | Answered on Nov 04, 2017
Take tub out, liner is cracked above motor do to off center load. Install new liner but cut fin off above motor before installing to stop this problem.
GE WBSR3140DW... | Answered on Oct 05, 2017
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
GE WBSR3140DW... | Answered on Jun 05, 2017
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
GE WBSR3140DW... | Answered on Apr 28, 2017
Connect the wires going to the sensor to each other to affect bypass.
GE WBSR3140DW... | Answered on Dec 15, 2016
Your shaft coupler / motor coupler has likely broke. Not too hard to fix yourself, but you will have to remove the water from the washer first.
Remove the clothes, place them in the bathtub. Roll a garden hose from the washer to outside where drain water won't matter. Tape the garden hose to the drain hose, and lower the drain hose to the floor. Water will flow through the garden hose outside. Turn the washer over, follow directions supplied with new part, and replace the motor coupling. When finished, reorient the washer, remove the garden hose, place drain hose in the drain stand pipe. Run the washer through a couple of full cycles, then rewash the clothing.
GE WBSR3140DW... | Answered on Dec 02, 2016
GE WBSR3140DW Top Load Washer Logo
1,337 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
bypass magnetic safety switch ge washer
  • Washing Machines
