20 Most Recent
GE WHRE5260E Top Load Washer Questions & Answers
GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
Where can I find a diagram of a ge whre5260e? I'd like to find the agitator.
When the machine agitates, it stops working. The belt has a lot of tension at this point.
stops working?? does it trip shutdown what
your info is far too sparse to make any definitive view
if the belt and rotors gears {egg gear} has failed
you would hear it grinding
so can you hear the motor running
ie youll hear the water circulation motor pump
usually one motor is used for both
if this is the case and the motor runs then its the gear system thats wrong
check the agitator motor start up capacitor hasnt failed
the info you give isnt good enough
Washing machine water level sensor not working
You can do one or 2 things. Drain the machine, disconnect the pressure tube going to the level switch and reconnect it. Check the actual switch itself and make sure it is working and also check that it hasnt fallen off and shorted itself against the frame of the washing machine. I see these switches fall off inside a lot.
GE WHRE5260EWW washer sounds like a jet when it spins
On a modern washer there will be an Engineers Program which is invoked by a key combination press. You can control all the functions from there and do tests. 1200 rpm is the Ideal speed for a washing machine for good reasons... Ask any Woman this !!Google your Model with Engineer Program etc.We have a range of Service Manuals at: www.spotless-service.com and adding many new ones everyday.
