20 Most Recent
Armitron Digital Sport #45/6967PNK Watch Questions & Answers
HOW TO SET THIS WATCH
just press and hold the "set" button then when some of the digits blinks it's the start of the setting of your watch. you can select what you want to adjust by pressing the "mode" and adjusting the digits that is blinking by "adjust" button.
How to set the wr330 watch lost instructions.
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words...
Button "A" is the button labelled "SET" in the upper left hand corner of the watch.
Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch.
Button "C" is the button labelled EL in the lower right hand corner of the watch.
Button "D" is the button labelled "MODE" in the lower left hand corner of the watch.
Setting the Time.
1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing.
2. Press and release D and the seconds on the time of day will begin to flash.
3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one.
4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit.
5. Press and release D to exit time setting mode.
How do I set the
- From Time Telling Mode, press 'A'.Seconds flash. Press 'C' to zero out seconds.
NOTE: Zeroing out 30 or more seconds automatically adds one minute to time.
- Press 'B'. Hours flash. Press 'C' to advance the Hour.
NOTE: Pressing and holding 'C' will advance digits rapidly.
- When 12 Hour Format is selected, 'PM' indicates 'p.m.' times; there is no indicator for 'a.m.' times.
- Press 'B'. Minutes flash. Press 'C' to advance the Minutes.
- Press 'B'. The Month flashes. Press 'C' to advance the Month.
- Press 'B'. The Date flashes. Press 'C' to advance the Date.
- Press 'B'. The Day of Week flashes.
- Press 'C' to advance the Day of the Week.
- Press 'A' to end set sequence and return to Time Telling Mode.
Need to set time, etc on this 3 button watch
Hi
I have found a PDF document that contains instructions for all ladies Armitron digital watches it can be found
here. It dosnt however contain instuctions for your model, but most of the watches it covers have the three button setup and may fucntion the same way.
Hope this helps
