20 Most Recent
Eiki LC-XG250 LCD Projector Questions & Answers
Have Eiki LC-XG250 projector. Recently
There is "NO" reset fuse. As the projector didn't turn, there might be millions of reasons. Might be an issue with lamp due to power outage or might be some other fault. There might be millions of reasons and you would agree. We cannot jump to conclusion that, it is Lamp. There might be an issue with power supply unit as well......
So, to be on a safe side, i would advise you to send it in for repair. This might be a small problem, However by trying to go for DIY ( Do It Yourself ), you might end up paying more bucks.
Rest, Decision is all Your's.
Thanks for using "Fixya".
LC-XNB4MS projector has a yellow
this has soething to do with bad timing of the lcd panels on the prism block. This is a common problem for this model.
You will have to replace the entire optical, which is very costly.
better invest your money in a newer model
I have an eiki lc
this depends on the signal type coming from your sources
best is using component signal ( Y-Pr-Pb) , by using the right cables and right settings for video inputs in the projector menus.In basic this should be possible.
Projector causes buzz in sound
buzz in sound is often caused by ground-loops, try to isolate audio
cables with so called groundloop isolator transformers ( 1:1)
available at high end audio shops or car audio centres
