20 Most Recent
GE APH10AA Air Conditioner Questions & Answers
Temperature setting rises up by itself no matter
Most window units are circuit board controlled. Most all electrical circuits like the fan motor, compressor, and heating, are powered through the circuit board, and distributed through different circuits in that board(control board). I would guess you have a circuit board malfunction. It's possible the thermostat is sticking, allowing the control board to misread a return air temp. Without some troubleshooting it will be difficult to pinpoint the problem but I'd bet it's one of the two.
My ge ac model APE07AHM1 is not blowing cold air.
This is an old question, but I am having the same problem with APE07AHM1 that I bought second hand. I'd like to recharge it.
The answer by binev_78 seems to be for outdoor AC compressor units but this is a portable stand alone unit, no outdoor unit.
Line voltage to the unit is too low
it sounds you know something about electricals...okay,try to put the cord from the unit to your lower arm and feel it if it is getting warmer in temperature,or the switch cover of your a/c wall switch.if not it`s better you have clamp meter for ampere testing and voltage measurment
GE APE07AHM1 Won't Run
This unit has a famous problem with the control panel. Try to use the remote to turn it on, instead of the panel. I had the same problem.
My GE A/C is leaking
Take a shop vac **** out the water from pipe. then take vinegar put a litte back in pipe this will kill the algee in the line
