20 Most Recent
HP Deskjet F4100 All-In-One InkJet Printer Questions & Answers
While printing 2 or 3 lines it shows paper jam
make sure you don't have any small pieces of paper stuck in the printer
Paper jams can be real or false. The unit may
report a paper jam when there is not any jammed paper, however, the solution to
a real paper jam or a false paper jam is the same.
WARNING:
Jammed paper
must be removed using the rear access door
and the power cord must be disconnected or a carriage jam or mechanical damage
may occur.
Do not remove jammed paper from the front
of the unit.
Turn off the HP product and turn it so the back of
the unit faces you.
Disconnect the power cord from the back of the
all-in-one. The power cord must be disconnected to allow the paper feed
rollers to turn freely.
Locate and open the rear access door by pressing in
on the left side tab and then pulling the door toward you.
Figure 1: Removing the rear access
door
Inspect the pressure rollers on the rear access
door and verify that they are clean and turn freely. Clean the rollers if needed
with a soft towel lightly moistened with water. If the rollers do not turn
freely, replace the rear access door.
freely, replace the rear access door. Click How to buy on this page to
order replacement parts.
From the rear access door opening, remove the
jammed paper.
Remove the remaining paper from the paper supply
tray. Discard any paper that is damaged or crumpled and then re-stack and reload
the paper into the paper supply tray.
Reinstall the rear access door.
Reconnect the power cord to the unit and turn the
unit on.
If a carriage stall occurs after clearing the paper
jam, resolve the carriage stall.
My hp deskjet f4100 deskjet won'
I was also having the same problem with my hp printer. So I called hp tech support phone number 1-800-585-2494 and they have fixed my hp problem instantly. hope this will help you better as well. for more information you can visit :
HP Customer service .
Thanks.
Lost my disk how do i install my hp deskjet F4100
A few days ago my HP Deskjet, 4100 Series, All In One printer just stopped working in the middle of printing. I got a new power cord/power pack and now the light comes on but there is no response when I try to print. It is as if the machine is not even turned on.
