20 Most Recent
HP Pavilion dv6-1122us Notebook Questions & Answers
Keys on HP dv6 do not work
sticky keys! hate that. Start>All Programs> Accessories> Ease of Access> Ease of Access Center > Turn off sticky Keys
Why does slotomania shut down my computer?
Does it shut down the computer completely or it just restarts it?This might be caused by overheating. Are there any signs of overheating in the computer? or outdated video driver. Try updating your video driver. You can also install Radarsync to automate the computer's updating mechanism.I hope this helps!Carlo
I have a HP pavilion DV6 laptop with preloaded
Use the free partition manager form EASEUS. Convert the partitions #3 and #4 into logical partitions containded both in the same extended partition (you can have only one extended partition, but it can contain multiple logical partitions, each with its own drive letter asigned)
Now you can using the same EASEUS to split the patition you wanted.
How do i get rid
- it's a virus, your Notebook affected by your pen drive or any other memory devices
- Scan your Notebook with a good anti virus
- allays use USB security software
- if still problem than reinstall your OS then follow the step 3 for further safety
My notebook had a bad
In that corner is the exit for the cooling air. If it's very hot that means that either the processor or the video chip are running at full throttle. Make sure all the economy setting in Vista are activated. If they are then the drivers (especially those for the proc and the AMD Cool'n'Quiet) are corrupted so reinstall them.
On puttin on my web cam it said
Click on your desktop and set your screen resolution to that size 1024x768, but I don't believe that’s the case cause most web cameras only put out 300 bit pictures but try it maybe it will work and afterwards you should be able to open the properties of the camera to change resolution
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
