20 Most Recent
Dell Inspiron Mini 10 Notebook Questions & Answers
STOP: c000021a {Fatal System Error}
0xc0000034 0x00000000 0x00000000 HELP?!
This is not an easy one to deal with if you don't have some things like a boot disk. The error is most likely caused by something that was installed or restored wrong. The best windows option is to use F8 and select last known good config. Then if it starts you can uninstall any software that you added just before this error..IF you cannot do that then you need to be able to boot to a separated disk and use file utilities to remove any programs that might be causing this.
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
I need remove bios password
By Internet
Contact Dell Technical Support online.
By Telephone
Please have your Express
Service Code ready. The Express Service Code can be found on a
sticker at the bottom of portable computers and on the back panel of
desktop computers.
Note:
If you cannot locate the Express Service Code, go to Technical Support Contact Us. Click Find My Express Service Code and Yes, I Do Agree. Make note of the Express Service Code that appears.
- Dell Technical Support at (800) 624-9896
- Dell Automated Support at (800) 247-9362
- If you purchased your computer through a Faculty, Student, and Staff
(FSS) program or an Employee Purchase Program (EPP), call (800)
456-3355.
How to fix xp anti-spyware
I am glad to HELP YOU!
Before anything else I'd like to offer you something to READ about that software that it gives you hard times with the search engines... It's
HERE. You will see there some explanations and some arguments.
And
HERE could be your solution.
I'd suggest you to get rid of that USELESS software and try a good antivirus/antispyware like AVG Free Edition [found
HERE] or Avira AntiVir Personal [also FREE and downloadable
HERE].
GOOD LUCK!
My dell inspiron mini 10 notebook using window 7
The Dell mini computer runs on a Intel Atom processor and has just 1GB of RAM on it.. So the computer is designed only for internet surfing and launching small applications.. Thats the reason it is called as a netbook.. It comes with win starter edition... It is not highly recommended running a win 7 pro on this machine.. It can be really slow on this Operating system... Thats the reason your computer is slow.. Try to run inbuilt cleaning like disk clean up to see if there is any iimprovements in speed.. Else switch the Operating system to win XP or Win 7 Starter
Battery of dell mini inspiron
Most batteries are not usable between systems. I would not recommend using one laptop's battery in a different model laptop. This can cause serious issues with the laptop and potentially damage it. I would recommend contacting Dell and ordering a new battery.
How to reset Toshiba A215 to factory defaults
You may follow the below steps to restore your Toshiba A215 laptop to its factory defaults:
Turn the Toshiba Satellite A215 computer off.
Press and hold the "0" key. Turn the computer on.
Release the "0" key when the Toshiba Recovery Wizard screen appears.
Click to select "Recovery of Factory Default Software" and then click "Next."
Click to select "Recover to out-of-box-state" and then click "Next."
Click "Next" on the confirmation screen to begin the recovery process.
Press any key on the keyboard to restart the computer when prompted. The computer boots up to the Windows setup screen.
Hope this helps..
