20 Most Recent
Amazon Kindle 2 Questions & Answers
My kindle won't wake up when i slide the power
Welcome to FixYa.
1. Make sure that your Kindle is charged properly.
2. Unplug it from the power source if it is plugged in.
3. Slide and hold the Power switch for 15 secs. then release.
4. Note that the Kindle screen will go blank for about 30 secs. while it restarts.
Thank you for using Fixya. Have a great day.
My kindle fire is frozen and won't turn off
Press and hold the power button for fifteen seconds or so, ignoring any "Shut down?" prompts, until it turns off. Release the button, then press and hold it for a second or two until it starts to reboot.
My Kindle froze, how do I reboot it?
there's a little pinhole at the bottom. insert a paper clip to do a hard reset. Or remove the battery and re-insert it to the same effect.
If all attempts trying to unfreeze it fail, you may have a logic board
issue. Are you sure the Kindle powers up? It may show something on the
sreen, even if it is not turned on (e-ink screen does not need a
powersupply to show an image). Try to power up your Kindle with a
different battery. If that fails, you can get the part at
Kindle Repair and there is a guide that shows you how to open a kindle and install parts at
Kindle Repair Guide.
I just downloaded a book
It all depends on the generation of Kindle you have. On mine I swip down from the top of the screen an the lighting an settings come up. Maybe this will help. Mine is 5 generation. On my earlier one it was different.
