20 Most Recent
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Questions & Answers
How to recover deleted text messages from the lg
If you go on to the menu and use the code 5,2 then press 0,1,1 very very quickly (if you dont do it quick enough then it will delete some of your messages) Then you go onto a screen of your deleted messages and you can chose to recover whatever one you want. HOPE IT WORKS :)
My LG KS360 hangs (takes
LG KS360 is widely known as a very slow phone. Literally, every key press is followed with some lag.
What you can do to speed it up at least a little bit is to delete unnecessary messages from your inbox, outbox, drafts etc., and also by cleaning up unneeded applications that you have installed.
If this helps, please rate.
Thank you
My incoming calls go straight to voicemail and
Friend,
goto Tools
then call
then Call divert and cancel all call diverts
then back to main menu
then to profile
then to general
then to personalise
then select a sound THAT IS LOADED ON THE PHONE- THEY MAY HAVE BEEN ACCIDENTLY DELETED
then select a reasonable volume
then save all and have someone call you
PJH1
What is the security code for LG ks360
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
- Volume Up + Home + Power
- Volume Down + Power
- Home + Power
- If none of the above work, do a web search for your phone's model plus "recovery mode".
- 3-
- Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
- You will be asked to confirm the factory reset.
- 4--
Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
How unlock lg ks360 so i can use my o2 sim card
To unlock it, you need the SIM Subsidy unlock code. This is unique to the individual phone and is provided by the Cell Carrier that originally sold the phone. Once you have the code from them, put your O2 sim into the phone and it should ask for the code. Type it in, then type it again when asked to verify.
After that you'll need to put in the settings for internet and mms for O2. Contact O2 and they may be able to send the settings Over The Air (OTA)
Free unlocking codes ks360
Free unlock code is not possible to get for LG KS360 model phone.You need to pay for this model to get unlock code.Visit the site
Mobileunlocksolutions.com get unlock code for this LG phone and unlock it easily.Then use Vodafone or any GSM network sim card in it.
