20 Most Recent
GE Monogram ZFSB26DRSS Stainless Free-Standing Refrigerator with Dispenser Questions & Answers
Water dispenser runs very slowly.
The filter may be the cause of the slow dispenser. They don't last forever.The inlet screen to the water solenoids where the water line connects to the fridge may be partially blocked. Heat from the night lite bulb can deform the plastic tube at the dispenser outlet and restrict the flow. Check all of the above and you'll find it.
Zfsb26drss - temperature will suddenly rise in
Please check step by step as following.
1. Compressor working.( keeping your arm on condenser coil to feel warm)
2. Check for whistling sound in freezer after few seconds of compressor starting. (If not, system chocked. call repairman)
3. If no chock, check thermostat setting. Keep freezer temp between -14 & 8* F and Fridge temp
36&46*F.
4. Check thermostat sensor is working by turning counterclockwise. If your fridge shuts off, it's o.k.)
5. If not, replace thermostat.
With your statement, it's cleared that thermostat cuts off is malfunctioned. Replace thermostat.
Thanks. Helpful?
Hi My GE Monogram Fridge isn't cooling very fast.
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Hooked up water, which dispenses invariably, but ice won't dispen
Remove the ice bin , and behind it , on the rear wall ,use a screwdriver for leverage , between the dispensor " arms " , to see if the arms turn the motor fairly freely and not jammed . If it seems jammed , use a hair dryer aimed at the center of the arms to heat up the motor shaft to melt any ice possibly freezing it . No disassembly required .
If the arms turn fairly freely ( not jammed ) , then the main control board behind the refrig , is the problem .
Unit wont start display only shows (hrs)
ok i tapped out and called the repair man. he came and found out the main board is fried.
you have to change the board.
he charged me 350 total for everything.
so all you have to do is order the board and do it yourself.
board is around 200-250 i think
For a GE refrigerator model GFSF6KEX, how do you remove the ice tray? (Not the freezer drawer, just the tray.)
To remove the ice tray from your GE refrigerator model GFSF6KEX, follow these steps:
Empty the Ice: Before removing the ice tray, empty it of any ice cubes. This will make it easier to handle.
Locate the Ice Tray: The ice tray is typically located in the freezer compartment, usually near the ice dispenser or ice maker.
Grasp the Bottom Edge: Stand in front of the freezer and open the door. Grasp the bottom edge of the ice tray on the sides. Be cautious not to place your fingers near the opening at the bottom front part of the bucket where the crusher blades are located.
Lift Up the Front: Lift up on the front of the ice tray so that it clears the stops on the ice bucket rail.
Pull the Tray Forward: Pull the ice tray forward and out of the freezer compartment.
Reinstalling the Tray: To reinstall the ice tray, follow these steps:
Line up the flange pieces on the sides of the tray with the channels in the ice bucket rails.
As you push the ice tray all the way back, lift the front of the tray so that it clears the stops on the front of the ice bucket rails.
Verify that the tray is properly inserted by pulling it forward. It should hit the stops on the rail and not come out. If it does, push the tray further back.
Check for Misalignment: If you're unable to push the ice tray all the way back, it might be due to a misalignment between the back of the auger (located in the tray) and the prongs on the auger motor (mounted in the back freezer wall). To fix this:
Remove the ice tray.
Close the freezer door.
Press the dispenser for cubed or crushed ice; you should hear a snap.
Open the door again and reinstall the ice tray.
Remember to handle the ice tray carefully, especially if it's full of ice.
