20 Most Recent
Hampton Bay 24750 Huntington III Ceiling Fan Questions & Answers
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (
website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Need a replacement remote for a Harbor Breeze fan 52 inch Yorkshire ceiling fan
Hey, hope you are doing well. I was able to source a replacement remote for you. The model number you are looking for is uc7080t for the replacement remote that works with the Harbor Breeze Yorkshire fan. https://remotecontrolplace.com/harbor-breeze-replacement-remote-controls/replacement-remote-uc7080t-for-harbor-breeze-and-hampton-bay-ceiling-fans/
Need a new blade
Need remotes
In theory, they should. Try Hampton Bay first, and if not, check for aftermarket replacements. Those remotes are simple enough that there is no reason that they can't.
Can a remote control be installed on the Huntington III?
Yes you can operate them with two styles of remotes: either the remote wall switch, or a hand held remote. Both require the receiver to be mounted above the top of the fan in the base it is wired to. The receiver has wires on both sides; the one side wires directly to the house wires, and the other goes to the fan and light. They are both sold at Home Depot and Lowes. The ones at Home Depot also include the set made by the fan manufacturer.
Ceiling fun
home depot and lowes carry hampton bay products, go to ceiling fan area and replacement blades and hardware are sold in packs of four and five. cheaper than buying a new fan. hope this helps.)
I want to install a ceiling fan. My ceiling is 80
mcdevito75 here, Hopefully your ceiling fan will go where there has been an already light fixture, if so, that light fixture shoud be mounted to the ceiling beam, and your new fan will be mounted the same way. If by chance your new ceiling fan is being mounted where nothing was ever mounted you"ll have to make sure the ceiling fan will mount to a beam, they are every 16 inches apart. This way you:"ll know that vibration from the fan won"t hurt anything.
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
I need to reverse direction of fan
mcdevito75 here, Close to the ceiling but still on the fan motor shroud should be another small pull chain switch, this pull chain switch is the fan reverse switch, the switch may also be a toggle switch but I doubt it. Look close to the other pull chain switch for the fan, for the reverse switch.
5 wire, 4 speed Zing Ear Switch ZE-268S5
The globe for my Hampton
Hampton Bay Ceiling Fan
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
