20 Most Recent
HKC 7" Touchscreen 8GB Tablet 1GHz Android 4.0 Questions & Answers
I need another ac charge
You have to find them through HKC. Not even radio shack has the round end to replace a broken one. It's exclusive to HKC. Try searching for the charger in amazon or ebay. You need the model number, starts with P then a few numbers like 771A. Just know they are exclusive so you get the right one when you're searching and that the model number will help
12/15/2015 7:23:27 AM •
HKC 7"...
Answered
on Dec 15, 2015
How can I fix my tablet
First make sure the tablet is charged up. Sometimes you just need to hold the power button down a little longer. If that does not work, most have a reset button that is recessed on the bottom edge of the tablet. You may need to get out the manual for the tablet to find the reset.
4/8/2015 6:06:32 AM •
HKC 7"...
Answered
on Apr 08, 2015
How can update my hkc tablet
I suppose you want to update to a higher Android version. I advise against it if you are a novice. First, you have to find an updated version of the ROM for your tablet specifically. Then, you will have to use an appropriate software to flash the ROM into your tablet. There is always a danger of bricking your tablet when flashing.
2/13/2015 7:12:38 AM •
HKC 7"...
Answered
on Feb 13, 2015
How to reset my hkc tablet
For and HKC 7" tablet there is no reset button however you can follow these steps to reset it first you power the device off completely next you hold down the power and volume up button simultaneously until the words HKC touch the wonderful world appears then you will release the power button only you will then find an android on its back you may release volume button then you will tap android or press power button to open the menu you use volume keys to scroll and power button to select scroll until you find wipe completely select that
1/1/2015 7:47:53 PM •
HKC 7"...
Answered
on Jan 01, 2015
How do i reset my hkc tablet model number p771a
This should do the trick,
1)Make sure the tablet is NOT connected to the charger
2) Power off the tablet by holding down the power button for about 10 seconds
3) Once it is off, hold down the HOME button and connect the charger while the button's being held down.
4) When you see the HKC logo come up, let go of the HOME button.
5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5.
6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again.
7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button.
8) Navigate to "Yes - delete all user data" and select it.
9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
Dave
12/3/2014 6:56:31 AM •
HKC 7"...
Answered
on Dec 03, 2014
Hkc tablet problems
That foil part is your battery. The battery is dead and you need a new one. You would need the tablet cleaned up too.
12/1/2014 7:11:50 PM •
HKC 7"...
Answered
on Dec 01, 2014
How to factory reset a hkc tablet model number a072d
Try this
1.hold down the power key for 10 seconds to turn off the unit with nothing hooked to the unit (no ac/no usb/nothing)
2. hold the volume up key (+) and the power, once the screen starts to turn on release the keys.
3. NEXT you should get a robot laying down with a red triangle, push the power key one time. This will get you to the menu screen.
4. from here you chose the reset factory by using the volume down (-). Once you have that line highlighted press the power button.
5. next use the (-) key to get to yes to reset/reboot followed by the power key to chose the option.
6. tablet will come back on and be just like you got it from the store originally.
10/21/2014 10:35:35 AM •
HKC 7"...
Answered
on Oct 21, 2014
Need to reset. grandson loged
Hard reset, Press the volume up and power button for about 10-15 seconds to reboot. Wipe data/Factory reset.
9/26/2014 11:14:18 PM •
HKC 7"...
Answered
on Sep 26, 2014
