20 Most Recent GE GTS22KBP Top Freezer Refrigerator Questions & Answers
GE- GTS22WC refrigerator. Both the refrigerator
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
1/18/2018 2:08:25 PM • GE GTS22KBP Top... • Answered on Jan 18, 2018
Deli drawer is stuck. Off-track. How to fix without breaking?
The Drawer might be frozen in the unit Take out your food from the freezer and let it defrost for an hour or two then you might be able to get the drawer back on track with just a little tug.
6/4/2015 7:27:37 PM • GE GTS22KBP Top... • Answered on Jun 04, 2015
Dairy products are seperating
Time & temperature. Even if kept at the proper temperature, dairy products will separate in time. Bacteria will also do it. If you drink from the bottle, the enzymes in your saliva will infest and break down the whole container. It's being digested in the container, like feeding baby food from the jar. The food in the jar becomes watery, because it's being digested.
11/18/2014 9:39:36 AM • GE GTS22KBP Top... • Answered on Nov 18, 2014
2answers
Water draining into frig
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
7/25/2014 8:46:09 PM • GE GTS22KBP Top... • Answered on Jul 25, 2014
0answers
0answers
0answers
Tbx22rfl
Be the first to answer 7/25/2013 9:31:10 AM • GE GTS22KBP Top... • Posted on Jul 25, 2013Be the first to answer
0answers
Tbx22
Be the first to answer 7/19/2013 4:16:20 AM • GE GTS22KBP Top... • Posted on Jul 19, 2013Be the first to answer
GE GTS22KBP Top Freezer Refrigerator Logo
121 questions posted
Top Refrigerators Experts
vince
Johnny 1000
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
freezer fan bearings very noisy
  • Refrigerators
