20 Most Recent Kenmore 3/4 hp Food Waste Disposer Questions & Answers
Not sure how to take apart disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Kenmore 3/4 hp... | Answered on Aug 15, 2014
Disposal parts get loose... as long as disposal is working, it is ok
Clean out with vacuum cleaner to remove stray parts etc
Gene
Don't install automatic start disposal:
Gene
h
Kenmore 3/4 hp... | Answered on Jul 26, 2014
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
Gene h
Kenmore 3/4 hp... | Answered on Mar 26, 2014
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Kenmore 3/4 hp... | Answered on Mar 23, 2014
Many parts are not available:
Copy following link for resources:
Gene
h
Kenmore 3/4 hp... | Answered on Oct 10, 2013
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
Add a comment and say where you are getting the parts and which model
Kenmore 3/4 hp... | Answered on May 26, 2013
TURN OFF POWER before sticking your hand in.!! But first check the reset button underneath the unit. Also, try to rotate the spinner with hex key usually provided.
Garbage... | Answered on Jan 17, 2019
Drink beer and then recycle glass bottle or aluminum can
Then research recycling route for all recycled and non-recycled waste products
Garbage... | Answered on Dec 04, 2018
Yes... all motors have start capacitor .. ''Without a start capacitor when voltage is applied, the motor would just hum''
Garbage... | Answered on Oct 11, 2018
Go to utube and watch the film.
Garbage... | Answered on Dec 26, 2017
Hello, Tom -
You may find this instructional YouTube video helpful:
https://www.youtube.com/watch?v=qC8LN32ep_Q
Garbage... | Answered on Dec 22, 2017
Kenmore 3/4 hp Food Waste Disposer Logo
13 questions posted
Top Kenmore Garbage Disposals Experts
Gene Haynes
Gil Shultz
Are you a Kenmore Garbage Disposal Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Garbage Disposals
Most Popular Question
kemore 3 4 hp disposal reach under hold
  • Garbage Disposals
