20 Most Recent
GE PDS22LBN Bottom Freezer French Door Refrigerator Questions & Answers
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
GE Profile PFS22MISBWW not cooling, power/lights on. LED & Fan off
This is a common problem with the GE Profile. In most cases this is caused by failure of the motherboard. If you would like a manual, part numbers and assistance on how to repair please let me know because the instructions are detailed and a lot to Wright if you are only wanting to know what is wrong. You can find a service manual by going here
http://appliance911seabreeze.com/
The fridge isnt cold but freezer is cold
You might need to have the oxygen added or the compressor replaced. Try switching the mains off for a day and leave all the doors open. This will help the ice build up between the freezer and fridge defrost to allow the cold from the freezer cool the fridge. This a temporary solution and it might give you a month before it builds up again.Mine had the oxygen added and the compressor changed and it was good as new after that.Good luck!
Where is the defrost timer
Remove the control knobs by pulling them. remove the plastic shield the
knobs went through, and your timer is to the right, you'll see a hole to
stick you screwdriver in to turn it. There is no control board. You
need to remove all shelves in the freezer section, and remove the back
in the freezer panel to get access to the evap and heaters. Hope this
helps get you in the right direction.
I need the part # for the icemaker ordered
Now here is the confusing part. If your model number is a GE PDS22LBN the Ice Maker would be part number WR30X10039 for the model number posted above your post. If you have sears model number for the refrigerator it will be like 312.235698 for example. Confirm the model number of the refrigerator and I can tell you the correct Ice Maker part number. Thanks Sea Breeze
