20 Most Recent
Quinny Freestyle 3 XL Dusk Jogger Questions & Answers
Quinny front wheel Quinny Freestyle 3XL are
Hi, I wouldn't try opening the wheel suspension as you will never get it back together, what I suggest is that you buy a new or used set of front wheels for you buggy on ebay, there is lots of spare parts to be purchased in very good condition. Regards marie
Quinny xl
Hi you might be able to get the parts on ebay
Can't remove seat from Quinny Speedi
As far as I remember (and this was a while ago) the seat is attached via black nylon straps that are connected to rectangular metal hoops. If you push the black strap around the hoop, you should see a **** in the metal, and the strap should pass through it, enabling you to remove the fabric.
This is a little tricky and will take a while, but should work.
I hope this helps.
Quinny Freestyle XL
I we to got the same style as you and after removing all the covers i dont think that it does go parent facing
Quinny 3 wheel
From the associated pictures, it appears the front wheel does NOT swivel. Generally jogger strollers do not have a front swivaling wheel because it may cause the stroller to flip while jogging. Jeep makes a stroller that has a front swival with a locking device on the front wheel, they also have these with a built in speaker system to attach mp3, cd players to. Sorry I couldnt be of more help. If you wantn to email me an actual photo of your stroller I will take a closer look and determine if it can swival. Just let me know on here.
Quinny pushchair puncture
A tire can be repaired with a regular bicycle repair patch. Otherwise you can use inflate a flat or tire slime to seal the leak, but you will have to rotate the wheel at a substantial rpm untill the repair sets, perhaps a powerdrill without a bit.
Bell
I would look online or email
[email protected] and they will let you know if it's replaceable. The service isn't quick though so be patient.
