20 Most Recent
Frigidaire Kenmore Washer Tub to Pump Hose 134455900 Questions & Answers
Need instrtuctions on how to use kenmore model 175.8899
If your Kenmore model 175.8899 is a common type of appliance like a dishwasher, refrigerator, washing machine, or oven, here are the general steps you might take to use it:
- Read the Manual: If you have the user manual that came with your Kenmore appliance, it's a great starting point. The manual will provide specific instructions tailored to your model.
- Power On: For most appliances, there will be a power button or switch that you'll need to turn on. Make sure the appliance is properly plugged into an outlet.
- Settings and Controls: Depending on the appliance, there might be various settings and controls you can adjust. For example, if it's an oven, you might need to set the temperature and cooking mode. If it's a washing machine, you might need to select the wash cycle and other options.
- Load the Appliance: Load the appliance with whatever you intend to use it for. For a dishwasher or washing machine, this could be dishes or clothes. Make sure not to overload the appliance, as this could affect its performance.
- Start the Operation: Once the appliance is loaded and you've set the desired settings, start the operation. This might involve pressing a "Start" button or initiating a specific sequence.
- Monitor and Wait: While the appliance is operating, keep an eye on it to ensure everything is going smoothly. For appliances like ovens or microwaves, this could involve checking the food periodically. For appliances like dishwashers or washing machines, you might just need to wait until the cycle is complete.
- Shutdown and Cleaning: Once the operation is complete, turn off the appliance using the power button or switch. For appliances like ovens, make sure to turn them off after use. Additionally, clean the appliance according to the manufacturer's recommendations.
- Maintenance: Regular maintenance might be required. This could involve tasks like cleaning filters, descaling, or replacing worn-out parts. Check the user manual for guidance on maintenance.
Remember, these are general steps, and your specific Kenmore model 175.8899 might have unique features or steps that aren't covered here. Always refer to the user manual for accurate instructions tailored to your appliance. If you're having trouble or need specific information, you might want to contact Kenmore customer support or refer to their official website for assistance.
Humidifier motor
The Kenmore 758.144161 is a humidifier that uses a motor to operate its fan and other components. If you are experiencing issues with the motor, there are several possible causes and solutions:
- Check the power supply: Make sure the humidifier is properly plugged in and that the outlet is working. If the motor is not getting power, it will not function.
- Clean the motor: If the motor is clogged with dirt or debris, it may not be able to spin properly. Use a soft brush or cloth to gently clean the motor.
- Lubricate the motor: Over time, the motor may become dry and require lubrication to spin smoothly. Use a light machine oil to lubricate the motor.
- Replace the motor: If the motor is damaged or worn out, it may need to be replaced. Contact Kenmore customer service or a qualified repair technician for assistance.
Note: Always disconnect the power supply before attempting to clean or replace the motor to avoid electrical shock.
HOW TO ACCESS DIAGNOSTIC CODES FOR TROUBLESHOOTING
www.
searspartsdirect.com/part-number/4738er1002a/0026/795.html
Part Information. Choose this manufacturer-approved tub-to-pump hose for yourwasher. This tub-to-pump hose replaces the damaged or leaky hose connecting ..
On google; Try to unplug it for a while, see if it resumes without error code.
Kenmore dishwasher 665.13129K703 is not flushing all water
Most likely problem is food particles or if jars and/or dishes with labels have been washed the scren protecting the scavenger water pump in the bottom of the dishwasher is blocked. Carefully feel around the screen for the blockage. I say carefully because it is a place to find broken glass also.
The microwave works at times and then does not work. What is wrong? a Switch?
Full closure of a microwave door is a serious safety item. Check the door for full closure. Is there anything in or on the hinges that might resist full closure. Check the latch mechanism for foreign objects even food on the latch. Also check around the sealing point around the entire door and mating seal. Closure should be a distinct snap.
