20 Most Recent
Pinterest.com Questions & Answers
How do I add pins to my Pinterest boards?
You can save Pins you find on Pinterest or add new ones from your favorite websites. Hover over a Pin you want to save and click Pin It. Or, click the Pin to see it close up and click Pin It. Choose a board for yourPin and add a description.
I got an email saying i changed my email on my pinterest account and name and i didnt
Hi
This may mean that your Pinterest account has been hacked or that it is a scam to get your details from you.
I suggest that you log onto your Pinterest account and check that all your details are still there and correct. If they are then the email should be ignored and deleted without taking any further action as it is a "phishing" email.
It is possible however that you may not be able to get into your Pinterest account with your usual login details or that on checking you find the details they are holding are not correct. In this case you need to change your Pinterest and email login details, especially passwords and let Pinterest know that you have been hacked.
Hope this is helpful, if so would you please register that with Fixya
Cheers
I am a Pinterest pinner. When I post a pin, I get
My guess is you hit pin several times while it didn't look like it was working and that's why it pinned more times. Every time you hit pin/entered it, it was actually working on their end. Sometimes patience goes a long way. I don't know if you ever experienced this but sometimes you might try to open a window and it just won't work, or so we think, but after it finally works, you get 5 windows popping up-only because each time it registered but we didn't think it did because it took forever. After one time of clicking, if it takes forever go take a break and come back. You can stop it and then refresh to see if it actually did take.
But if you find a pin that will just not pin after clicking it only once, go here:
PIN FAIL
Can not post pics on pinterest my page turns white
It could be a corrupt temp file or a security issue between their server and your computer.
To test this:
Close that browser
open a blank page and clear history
go to run and type temp then press enter- select all and delete
go to run and type %temp% then press enter-select all and delete
Can even go to Accessories/Tools and select disk cleanup and run that and check any boxes with junk in them.
Go back to pinterest and try again.
If that doesn't fix it then try this:
Change your privacy settings
At this point if the problem is not fixed, I would contact them in the help section (down at the bottom of the page I listed).
I hope this helps.
PINTEREST IS DRIVING ME CRAZY - CAN'T RESET PASSWORD AND NO HUMAN HELP
I hope they get back with you soon! In the meantime, have you cleaned out all of your history from browser and computer? That could be preventing the change if something is corrupted. It could be a security issue between their server and your computer.
To test this:
Close that browser
I hope this helps.
How do I sign out of pinterest when I am finished working on it?
Hi! If you are on a cell, click on the 3 dots in the upper right corner - LOG OUT will be at the bottom of the list to click on. On a pc, in the upper right corner you'll see EDIT PROFILE. Next to that is a black wheel. Click on it. LOG OUT is at the bottom of the list to click on. I hope this helps!
