20 Most Recent Eagle Propane Buffer Burnisher Contractor Series Kawasaki 17 HP Engine 27 Inch With Pad Holder 1800 RPM, Steel Tank, 12 Volt Battery Starter, 300236 Questions & Answers
Use your volt meter to test the battery voltage. It should be at least 12.4v . I this is good, follow the voltage through the ignition switch and the relay if it has one, on to the starter. If you have power on to the starter, but still no crank, the starter is bad.
Hope this helps, Robert
Eagle Propane... | Answered on Oct 31, 2018
Any janitorial supply in your town, or ebay. Your Home Depot or Lowe's may have them as well as Amazon.
Floor Polishers... | Answered on Jun 28, 2019
The rectifier is in the top end of the motor. Take the cover off and then the top end plate of the motor. With the bolts removed, you will have to tap and rock the plate to evenly remove it. Carefully look at the marks on the old and new part to be shur you do not make a mistake in the wiring. A drawing and photo might be nice too.
What exactly is the question here?
Is this a corded electric Scrubber or a battery one?
Floor Polishers... | Answered on Dec 27, 2016
Timber Floor Sanding and Polishing Melbourne
Use this guy, i have used them before & they are very affordable & professionals for sure
Floor Polishers... | Answered on Mar 29, 2016
motor bearing worn or shaft bent.
Floor Polishers... | Answered on Aug 10, 2014
Wax remover. Rewax spot after removing wax.
www.electroluxappliances.com/Owner-Support
www.cleanfreak.com/Qstore/p001525.htm
the brush is either dirty or you burned the wax.
Plug it in,pull trigger
Floor Polishers... | Answered on Jul 31, 2014
Eagle Propane Buffer Burnisher Contractor Series Kawasaki 17 HP Engine 27 Inch With Pad Holder 1800 RPM, Steel Tank, 12 Volt Battery Starter, 300236 Logo
2 questions posted
Top Eagle Floor Polishers & Buffers Experts
Robert Wooley
Robert Wooley
Bishop and Son...
Bishop and Son...
Level 1 Expert
Are you an Eagle Floor Polisher and Buffer Expert? Answer questions, earn points and help others
View Most Popular
  • Eagle Floor Polishers & Buffers
Most Popular Question
17hp kawasaki propane buffer wont crank
  • Floor Polishers & Buffers
