20 Most Recent Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Questions & Answers
3answers
Leak around the door seal
the seal might look ok but don't forget the seal could crack on the bottom, any time the washing machine stops and the water settle there's more water at the bottom half so the bottom of the seal takes more abuse. so I would replace the sealer and if you can buy a little thicker one.
2/7/2018 5:27:41 AM • Samsung WF218ANW... • Answered on Feb 07, 2018
Why doesn't it drain and displays code nd?
The drain pump is either blocked or failed. Have you cleaned the drain filter?
11/8/2015 1:59:17 PM • Samsung WF218ANW... • Answered on Nov 08, 2015
Why isn't it filling?
The water valve has most likely failed and it will need to be replaced.
11/8/2015 1:41:37 PM • Samsung WF218ANW... • Answered on Nov 08, 2015
Samsung waching machine won't drain
If you don't have the DIY skills to fix what is probably the drum bearings or water pump gone then an appliance engineer is your next bet. Is there excessive movement in the drum itself? Does it turn smoothly? Switch off at the wall, remove the access panel and see if the drive belts are OK. The grinding noise could be a coin trapped between the drum and the drum casing. None of this is an easy fix. Keep in mind the age and usage if you get an estimate, maybe cheaper to buy new?
8/12/2015 10:28:22 PM • Samsung WF218ANW... • Answered on Aug 12, 2015
Samsung front load washer will turn on but will not let water in to start wash cycle.
the humming sound is the coil for the solenoid that activates the water valve have an technician replace it or if you are not using hot water ,change the hoses at the taps and use a hot water setting
3/25/2015 5:31:38 AM • Samsung WF218ANW... • Answered on Mar 25, 2015
How to clear codes
i found this in another place Quick Test Mode Note: This test erases all faults and memory: To enter press Spin, Soil, & Power simultaneously with the power off. 1. All LED's light up and the washer beeps as it enters the Quick Test Mode. 2. The unit displays the software version for a second then clears the EEprom. 3. After the displaying the software version, LCD will display Model information. If EEEE is displayed the PCB assembly is defective. For production up to 03/31/2009 Serial **S3** 4. When the version is displayed. Press the following keys to test the various components. Effective 4/1/2009 Serial **S4 ** a change was made. 4. After the displaying the software version, turn the Jog dial CCW to display "F4". Press the following keys to test the various components. Press Temp Key to cycle through the Water Valves in this order: Cold Main, Bleach, Cold Main & Bleach for Fabric Softener, Hot, then off. Press Spin Key to test Motor circuit. Press Signal Key to test Drain Pump Press Soil to test door lock - unlock circuit
3/6/2015 1:46:54 AM • Samsung WF218ANW... • Answered on Mar 06, 2015
How much does it roughly cost to replace the door seal front load washer ?
Approx 60.00 Us dollars
1/9/2015 12:15:57 AM • Samsung WF218ANW... • Answered on Jan 09, 2015
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW dc = Unbalanced load prevented the washer from spinning. What Do the Information Codes Mean on the Front Load Washing Machine
1/3/2015 12:35:11 AM • Samsung WF218ANW... • Answered on Jan 03, 2015
How do I replace the back tub on a front load washer.
ck with youtube it should be there
12/15/2014 5:48:53 PM • Samsung WF218ANW... • Answered on Dec 15, 2014
Washer stops mid cycle
Look under the machine cabinet for a bag with the diagnostic manual
10/16/2014 4:55:28 AM • Samsung WF218ANW... • Answered on Oct 16, 2014
Washer is stuck on one wash cycle
What cycle ? Did you ck pump for trash ? Any error codes pop up ? Need more info .
10/15/2014 7:56:32 AM • Samsung WF218ANW... • Answered on Oct 15, 2014
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
122 questions posted
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
samsung waching machine drain
  • Washing Machines
