20 Most Recent
Xerox Phaser 3250D Laser - Monochrome Laser - 30 ppm Mono - 1200 dpi - USB - PC, Mac Printer Questions & Answers
I have a solid red
I found a solution from xerox website (the link below). If you did not tried it already, you can give it a try.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=430,E=0000000002875885450,K=9805,Sxi=12,Solution=obj%283097%29
Hope this helps
Xerox 3250 printer
The transparency should have a white peel off strip! Without that the machine doesn't know it feed paper. Some transparency paper will have a backing sheet you peel off after printing. Check Staples for correct type.
This should be the edge that feeds first and should be on the on the non print side. if your not sure which side is printed on (face up / face down) open tray and draw an X on the top sheet.
then print anything and see if it prints over the X. If not then put peel off strip on the side (face up / face down) not printed on .
