20 Most Recent
Vizio VW26L 26 in. LCD TV Questions & Answers
Tv won't read the cable when hooked to the cable wire without cable box
Hello, Mary -
Your cable TV provider probably requires all TVs accessing the cable service to have their own cable converter boxes.
Note: An extra cable converter box will probably cost an additional monthly fee.
We have AT&T Uverse as our cable TV provider and need a cable converter for each TV.
Picture but no sound
try to play a DVD if works fine on DVD..your problem is the reception of antenna or digital connection..
Remove back
If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Remote works however will not turn on the tv
Please take this steps on how to determine the problem:1. Open the back cover.2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..4. If the power supply output is normal..The problem could be on the main board...5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..Hope this solution will be helpful..
