20 Most Recent Olevia 237T 37 in. LCD TV Questions & Answers
2answers
Tv power light comes on when i turn on switch in
your on a safe mode energy saver they built then tvs like that for storm and lighting storms ok only push power button one then wait 15 min. then tv should come on.
3/30/2018 11:08:55 PM • Olevia 237T 37... • Answered on Mar 30, 2018
Olevia 237-T12 image flickering and jumping. Flickering with horizontal lines appear after about 1 minute after turning on the TV. What part to replace?
The tcon board is responsible for the image on your screen as well as any anomalies you see.
9/1/2017 12:47:13 AM • Olevia 237T 37... • Answered on Sep 01, 2017
0answers
Does ANYONE have an Olevia TV? 237 T11 still??
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
10/17/2016 11:20:52 AM • Olevia 237T 37... • Answered on Oct 17, 2016
Lost power to house, power comes on. TV on off light just blinks, TV doesn't turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ If blinks continue without any pause, the main board is faulty.
5/27/2016 3:52:48 PM • Olevia 237T 37... • Answered on May 27, 2016
Can't turn closed caption off.
Go in ur tv menu go" Picture" go down to reset, press it the tv will back to factory setting.If the Captioning still there.Than ur Tuner Main signal board have problems.
2/6/2016 12:58:14 AM • Olevia 237T 37... • Answered on Feb 06, 2016
How should the rca connection for TV Hd look
Should have AV in a red socket and a white socket (Audio) and a Yellow socket for Video cable. 25716067-vyt5ihotjzh4lfxt3msubbsh-3-0.png
5/27/2015 2:08:42 PM • Olevia 237T 37... • Answered on May 27, 2015
0answers
I can not get full screen on all channes
Some programs broadcast the picture that way and the only way to make it full is to select the stretch or zoom feature but even if you are on full screen if they dont broadcast it that way it will not be a full picture.
1/27/2015 1:07:47 AM • Olevia 237T 37... • Answered on Jan 27, 2015
What are the codes for my olevia tv?
Is this a real question that you want an answer to? Try giving some information we can work with!
12/8/2014 1:05:48 AM • Olevia 237T 37... • Answered on Dec 08, 2014
My 237 t does not coome on all of the time. Sometimes it just blinks blue. Could it be the capcitors going out in the power board?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
12/2/2014 5:16:40 PM • Olevia 237T 37... • Answered on Dec 02, 2014
My ole is television powers off after a few seconds and won't stay on
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
10/30/2014 2:47:45 PM • Olevia 237T 37... • Answered on Oct 30, 2014
Olevia 237T 37 in. LCD TV Logo
225 questions posted
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
not get full screen all channes
  • Televison & Video
