20 Most Recent Motorola Talkabout T5420 (14 Channels) 2-Way Radio Questions & Answers
Radios not turning on..
There is no repair guide. M never wanted these repaired. I suspect liquid damage. Get a small Torx screwdriver, likely a T-6 and unscrew all the screws, making certain you located the one near the antenna. Open? Look at the main board. If there is a whiteish coating, it is liquid corrosion. If you want to try repair, get some rubbing alcohol, a clean rag and q tips. Start with the rag, dip and rub, but not hard. Do not dislodge the small parts on the board! Then move onto the q tips for smaller areas. This can easily take 30 minutes to do a good job. So, you have an hour a radio into the repair, maybe more and no guarantee it will work when done. You can test the radio while apart by holding the battery to the contacts. Best of luck!
1/18/2018 10:10:31 PM • Motorola... • Answered on Jan 18, 2018
I have a set of motorola fv700 talkabout radios.
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
9/10/2017 12:27:40 PM • Motorola... • Answered on Sep 10, 2017
How do you change the "code"?
http://shop.giantintl.com/Manuals.asp?offset=30
12/17/2015 12:28:40 PM • Motorola... • Answered on Dec 17, 2015
I have two talk about radios that use to
See the red LED is lit when you pressing the PTT. If it is working then you need to see the Radio hardware side specially PA and associated circuit. Also see when you press the faulty Radio PTT your good radio have any response. See its green LED lit or you hear any click sound.
11/6/2015 3:19:35 PM • Motorola... • Answered on Nov 06, 2015
How to change the side channel or code
Here is a link to the user guide for the T5420 http://content.giantintl.com/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf Programming instructions start around page 15. Best regards.
10/27/2014 3:45:22 PM • Motorola... • Answered on Oct 27, 2014
Replace a key actuator pad that is torn bad
The rubber key cover is one piece and not sold as a spare part. Take the radio apart, remove the pad and put a thin tape, such as a very high quality electrical tape and a small amount of RTV silicone under the tear. Reassemble, wiping off any extra RTV as you go.
11/12/2013 4:54:01 AM • Motorola... • Answered on Nov 12, 2013
I have the midland gxt 1000/1050 series X-Talk
The CTCSS (receive code) is not set to match the transmitting radio. They must both have the same code set in order for you to hear each other.
11/7/2013 4:44:54 AM • Motorola... • Answered on Nov 07, 2013
0answers
T5420 manual
Be the first to answer 8/2/2013 4:01:09 AM • Motorola... • Posted on Aug 02, 2013Be the first to answer
Motorola T5725 - Earpiece with mic wont work
A few things you might check:1) Be certain the radio is turned off when plugging in any audio device.2) Be certain the device is plugged in all the way. You should feel it seat, or click into place.3) Use a device designed for your model radio. Aftermarket accessories don't always have the functionality of the OEM device.4) Be certain you have special features such as VOX turned off on your radio.Hope one of these helps.Best regards.
3/27/2013 2:04:57 PM • Motorola... • Answered on Mar 27, 2013
3answers
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
11/17/2011 12:23:26 AM • Motorola... • Answered on Nov 17, 2011
I am looking for a
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa
Your feedback is important to us!
Kindly rate and accept the solution if it helps you.
9/8/2011 6:08:40 PM • Motorola... • Answered on Sep 08, 2011
Why can't i hear people when they try to talk to
Possible that the earpiece is defective or there are errors in the circuit. The earpiece can be checked using multimeter, if open must be replaced.
If not there is fault in the circuit and must be probed with a signal tracer
2/19/2011 4:28:39 AM • Motorola... • Answered on Feb 19, 2011
I can transmit but not receive a reply
Check to see your interference eliminator code and Qt filter (if any) are set identical among your radios. For basic operation, set these to off (zero).
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
Best regards.
1/11/2011 4:26:21 PM • Motorola... • Answered on Jan 11, 2011
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
45 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
am looking
  • Radio Communications
