20 Most Recent
Insignia NS-LCD37 37 in. LCD TV Questions & Answers
The screen is black.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2/17/2016 2:26:10 AM •
Insignia...
Answered
on Feb 17, 2016
TV is not a smart tv how do I get netflix
If your t.v. doesn't have the Netflix app installed in the unit, your best bet would be to get a Roku box and hook it up to the t.v. and use that as your source for Netflix. That would be the easiest and cheapest way.
8/2/2015 7:59:53 PM •
Insignia...
Answered
on Aug 02, 2015
How can I reset an insignia TV without the remote
You should have to enter its service mode option to do this. To enter the service mode, you should have its remote control.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
8/7/2014 11:54:09 AM •
Insignia...
Answered
on Aug 07, 2014
My Insignia NS LCD 37 will power up but the screen is gray and there is an even lighter gray bar going up and down but no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
4/8/2014 1:02:45 AM •
Insignia...
Answered
on Apr 08, 2014
Insignia lcd32 screen is green and purple even after replacing tcon board.
Have you checked all your input cables & connections? Does it do this on all inputs?
If all inputs act the same & all cables are known to be good, then Most likely the Main PCB.
Part#s, price & availability listed at the following site:
http://www.shopjimmy.com/insignia?restrictBy[master+part+type]=Main+Board
11/30/2013 10:16:22 AM •
Insignia...
Answered
on Nov 30, 2013
Insignia bluray/tv combo 2009 player read error
Disc(s) could be damaged. If this is not the case, then you would need to setup repair service by callingU.S. and Canada - 1-877-467-4289Mexico - 01-800-926-3000 We're here to answer your requests daily from 7 am - 12 am CT.
10/16/2013 7:16:55 PM •
Insignia...
Answered
on Oct 16, 2013
