20 Most Recent
Element ELC-HS321 32 in. LCD TV Questions & Answers
My Element Flatscreen works sometimes.
That you have an intermittent issue in the power supply that at some point in future will become permanent rendering your flat screen DEAD. The time is coming so start saving some bread for the eventuality.
8/31/2017 9:57:22 PM •
Element...
Answered
on Aug 31, 2017
My tv 50" element tv flat screen
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
7/1/2016 3:56:59 AM •
Element...
Answered
on Jul 01, 2016
How do I program my Charter remote to an Element TV?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
3/3/2016 9:15:43 AM •
Element...
Answered
on Mar 03, 2016
Auto scan issues??
The main system control memory IC fault. Check and replace it.
Before replace it, try a hard reset to this set. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1/20/2016 2:49:29 AM •
Element...
Answered
on Jan 20, 2016
Won't turn on
There may be a number of reasons from a blown fuse to a bad power supply unit responsible for your problem. Please consult some local TV Tech.
1/3/2016 9:37:09 PM •
Element...
Answered
on Jan 03, 2016
Need code from rcauniversalremote
http://electro-medical.blogspot.com/
1/1/2016 4:03:36 PM •
Element...
Answered
on Jan 01, 2016
Why am I stuck on one channel
There is only one channel in auto search. Just open searching menu and auto search again your new channels.
7/9/2015 11:29:03 AM •
Element...
Answered
on Jul 09, 2015
Tv wont turn on the red light is on but will not
my tv has the same problem. I found if you unplug the TV for a couple of days, then plug it back in, it should work. The tv will also do this whenever there is a power failure or if you unplug the tv to use the outlet for another device.
6/26/2015 11:44:00 PM •
Element...
Answered
on Jun 26, 2015
Fix my color
If you wish to fix your color, just visit any beauty parlour.
12/30/2014 9:02:17 AM •
Element...
Answered
on Dec 30, 2014
