20 Most Recent Vizio VO42L 42 in. LCD TV Questions & Answers
2answers
Lost my Vizio VO42L base stand screws (8). Can I
The exact size for this and almost all visio TVs are: M4 x 35mm at .70 pitchHope this Helps the next guy/gal that looses their screws...
6/5/2019 2:42:23 AM • Vizio VO42L 42... • Answered on Jun 05, 2019
The picture on my Vizio 42
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
8/8/2018 12:34:37 PM • Vizio VO42L 42... • Answered on Aug 08, 2018
I have just use the TV 2 DAYS, when I play XBOX
If I'm understanding you correctly this is a two-day old television? If that's the case it should be under warranty, return it to the vendor.
1/4/2018 10:35:15 PM • Vizio VO42L 42... • Answered on Jan 04, 2018
Vizio vo42lfdtv10a Turns on the vizio name light,
I will check out the back lights inverter board first if there is any defective electrolytic capacitors or not, if not, the problem is the main board.
11/24/2017 1:06:18 AM • Vizio VO42L 42... • Answered on Nov 24, 2017
TV won't power up. Yellow standby light is on but when I push the power button, yellow turns white then immediately back to yellow.
Hi, There may be some problem with the power supply section. Please consult the service center.
10/11/2014 9:46:39 PM • Vizio VO42L 42... • Answered on Oct 11, 2014
Can't turn tv off or on with remote.
Main system control section circuit fault. Contact any service technician to get it repaired. The 5V supply line voltage should be checked. Gopakumar Gopalan Google
8/6/2014 2:16:19 PM • Vizio VO42L 42... • Answered on Aug 06, 2014
Found a Vizio VO42L By the dumpster and want to try and repair it. I plug it in and the orange logo lights up, press power and it turns on and the logo lights up white but picture flickers with horion
Sounds like it might be a solder joint. use the meter and check the ohms on each side of the solder joints on the board where the serial cables connect to the boards. it would be a good idea to check as many joints as you have time to. If it is a LED TV check Led control board for bad joints. if it uses Flourocarbon tubes check the transisters on each lighting control board. you may only have one board working causing partial back lighting.
7/29/2014 2:56:12 AM • Vizio VO42L 42... • Answered on Jul 29, 2014
Vizio M421vt no picture
If audio is OK, the fault should be with its backplight inverter baord. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
4/22/2014 6:26:38 AM • Vizio VO42L 42... • Answered on Apr 22, 2014
2answers
"flickering" of tv
does the VIDEO FLICKER and the screen stay lit? Then it's the Video board, but if it Blacks out it's the Inverter if it's an LCD and the Ysus if it's a Plasma...
You still have to send it to Vizio to get it fixed
12/8/2012 5:02:23 AM • Vizio VO42L 42... • Answered on Dec 08, 2012
I have a 42
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
11/10/2012 1:25:46 AM • Vizio VO42L 42... • Answered on Nov 10, 2012
Vizio VO42L 42 in. LCD TV Logo
87 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VO Vizio
  • VO Vizio
Most Popular Question
lost vizio vo42l base stand screws 8
  • Televison & Video
