20 Most Recent
Hasbro Furreal Friends Butterscotch Pony Questions & Answers
Parts list how can I get a parts list?
For the FurReal pony full size? It would do you no good; Hasbro does not make them, has ZERO inventory of ANY parts, and most of the time, you need to be innovative and/or creative. What parts do you need?
Butterscotch pony
Hey, the blue and grey wire under the neck fur does not connect to anywhere. It was likely a debug port while Hasbro was testing the ponies. You can try moving the ear by hand when it's supposed to move but it is likely broken inside the head and would need a lot of work to repair.
Battery replacement
Hey, replacement parts for Butterscotch can still be found on ebay, though I can't seem to find a battery holder now. You can check it from time to time and see if one pops up.
Battery pack not working
Can you elaborate? Is is corroded? If so you can clean it yourself and scrape off any rust or corrosion, just don't forget to wash your hands afterwards.
Charger
The Furreal Butterscotch pony is operated by 6 D sized batteries.
To replace them open the velcro on her belly and loosen the screw holding the battery compartment. You can then replace the batteries and turn the pony on after repeating the procedure backwards.
