20 Most Recent Peg Perego John Deere Turf Tractor Questions & Answers
this is definitely in the wrong category
Peg Perego John... | Answered on Aug 18, 2017
there is no transmission on these toys
these toys do not have a starter
this category is for the toy tractors
i think you posted in the wrong category, this is for the toy tractors
these toys don't have engines just electric motors
check to see if both wheels are spinning in forward, if not you have a bad motor
Peg Perego John... | Answered on Aug 17, 2017
disconnect one of the motors and see if the problem is fixed, if it is then it is a bad motor
pop off the center caps from both rear tires with a flat head screwdriver, and then remove the push nut washers by bending them with a pliers and removing them (keep in mind this will ruin the existing push nuts and replacements will need to be purchase from ebay or somewhere similar) then slide the tire off of the axle and replace (do not remove the axle cause there are spacers inside the vehicle that will fall out of place)
release the clips from underneath with a flat head screwdriver to release the gas pedal assembly
sounds like a bad motor, swap the motors cables from left side to right and see if the problem follows if it doesn't then you need to replace the motor
Peg Perego John... | Answered on Aug 16, 2017
sounds like a bad motor, swap the motor wires between the two sides and see if the problem persists if it does its the shifter switch, if it doesn't its the motor
Peg Perego John... | Answered on Aug 15, 2017
check your charger with a multimeter and make sure its putting out at least 13.8 volts
did you verify the battery voltage with a multimeter, could have a bad charger that gives a green light making one think that the battery is fully charged, also check the fuse on the battery
Peg Perego John Deere Turf Tractor Logo
147 questions posted
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
need shifter stopper john deer tractor
  • Toys
