20 Most Recent
Panasonic KX-TG2356 Cordless Phone Questions & Answers
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
4/19/2017 12:50:54 PM •
Panasonic...
Answered
on Apr 19, 2017
When a call comes in
your phone gets calls in and will associate the name it reads. For example if your friend JOE calls tthen the system will say Call from Joe. But if the number is unlisted or blocked the Call from Number Available message will sound. If you don't have call display the all number coming in are imarked as Number Available.
8/9/2011 1:00:25 AM •
Panasonic...
Answered
on Aug 09, 2011
WHEN A CALL COMES IN
The answer to this is quite involved. You must first prepare the answering system, decide if you want to record your own personal greeting, how long you want the actual recording time to be and number of rings before the machine answers and then set the system to answer on.
This whole process is quite involved and takes up several pages which is impractical to reproduce here, so rather than copying it all here I am providing a link to the manual for this phone.
Please refer to pages
20 to 24 inclusive and
52 to 56 inclusive regarding how to set up the answering machine and how to listen to playback of messages. Link is below;
http://service.us.panasonic.com/OPERMANPDF/KXTG2356.PDF
Thanks for using FixYa. Please remember to leave a vote for the solution.
12/12/2010 3:22:22 AM •
Panasonic...
Answered
on Dec 12, 2010
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
9/27/2010 8:58:31 PM •
Panasonic...
Answered
on Sep 27, 2010
Panasonic KX-TG2356 Cordless Phone key pad
Open the hand set by Removing battery, remove 2 screws under battery, carefully open handset casing by prying open with thin bladed screwdriver, remove pc board by removing 3 retaining screws, on opposite side of pc you will see contacts for handset buttons clean with eraser and reassemble handset.
4/4/2010 7:42:28 PM •
Panasonic...
Answered
on Apr 04, 2010
