20 Most Recent
Mtd Products Yard Machines 158CC Tiller Questions & Answers
Trying to remove sterring shaft screw under the body
the screw has lock ty-et and yes its a pain we run in to this all the time just keep trying or heating it up helps most of the time we cut them out. you'll have to remove the deck. when we reinstall we put a bolt head type back in. good luck
Mower blades belt keeps breaking
Did you get a manufacturers belt? sometimes belts that look the same don't work. My belts kept breaking because the pulleys were dirty with grit, dirt, and grass. Hope this helps.
How do you start the Huskee Rototiller 190CC? My
Yes, the engine is identical to the ones used on several lawnmowers and the safety bar must be held in against the handle to enable it to start. Releasing it while running will kill the engine.
How to find replacement clutch cable M T D rear tine tiller with no sereal number
you can do what i did and resoider or re crimp the cable go to the hardware store and buy a generic cable and fabricate your own.i did this for my 2 year old mtb lawn tractor as i was too cheap to spend the 50 buck for a crappy 1/8 thick cable that the manufacter knew was going to fail.I used a spare throttle cable from my vw dune buggy and cut it to fit.
158 series
it probably wouldnt hurt to replace filters and clean carb that should fix the problem
