20 Most Recent
Panasonic NN-T990SA Microwave Oven Questions & Answers
Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
7/17/2021 10:31:17 PM •
Panasonic...
Answered
on Jul 17, 2021
My microwave says "child" and won't play anymore
Not sure of the TT series models but for the NN series models the procedure is as follows:-
If "Child" is displayed in the display window, then the child safety lock is on.
To remove the child safey lock, press the "Stop/Reset" button 3 times in fairly short succession (less than 3 seconds). The time of day or just the Colon sign (:) is then displayed
If you later want to apply the Child safety lock, then, when the time of day (or colon sign) is displayed, press "Start" 3 times (again in short succession).
Hope this helps
Doug
2/6/2018 5:21:45 AM •
Panasonic...
Answered
on Feb 06, 2018
The door latch won't close. The light stays on.
The problem is an engineering defect. The mechanism that engages the door latch is mounted to a steel plate that is "L" shaped and when you close the door it pushes against and bends this plate out of position. After a while the metal plate fatigues and stays bend out of position and the door stops engaging and locking so the two safety switches inside don't get depressed. Result door won't lock and light stays on. I had to re-engineer it by cutting the tube of a pen to size and placing it in as a support bracket to put pressure on the plate so it won't bend anymore. My wife was going to throw it in the trash. Note of caution: I did cut my hand in several places trying to get the bottom cover on and off the microwave as the metal edges are razor sharp!!! I love this microwave it is my second one.
3/10/2015 2:05:10 PM •
Panasonic...
Answered
on Mar 10, 2015
How does one replace the light bulb in the Panasonic NN-T990SA countertop microwave?
you have to remove the plug and then the outer casewhich is 4-5 screws on the back,you will find a air duct on the left hand side of the magnetron which is a metal box with two wires on the bottom.the bulb hosing is kept in with a screw and a metal tab,undo the screw and remove the two wires and that is the unit you have to replace,it is called a cap less bulb as it is one unit,reassembly is the reverse.hope this helps regards les
11/9/2014 6:08:24 PM •
Panasonic...
Answered
on Nov 09, 2014
The power just went off. tried unplug for 20 secs and plug again. tried the braker and plug. still nothing
Plug a lamp into the wall receptical, if it works! the main fuse in the microwave has blown. Unplug, and remove the top "several screws" check under the keypad and follow wires to the circuit board, look for a silver rectangular capacitor, take a screw driver and short the two points to remove any residual voltage. Now look for a small fuse "clipped" pop with screwdriver and replace with the same current rating, assemble unit because lethal voltages are present when powered on.
10/15/2013 7:47:19 PM •
Panasonic...
Answered
on Oct 15, 2013
