20 Most Recent Eureka Atlantis 2595A Upright Wet/Dry Vacuum Questions & Answers
0answers
Eureka Atlantis Opti Heat - DON't WASTE YOUR MONEY
fixya site is not the public media for this complaint put it on face book so the world gets to know of the shonky manufacturer
10/7/2017 2:07:08 AM • Eureka Atlantis... • Answered on Oct 07, 2017
Someone told me since I didnt have a filter for my
I'm surprised that you think a cost cutting bodge up job would do the trick! You will be lucky if it hasn't damaged the vacuum! See your dealer and get a filter for the job. It will be cheaper than paying out for the repairs for a new cleaner.
8/19/2013 6:29:18 PM • Eureka Atlantis... • Answered on Aug 19, 2013
3answers
EEureka Atlantis 2595A Upright Wet/Dry
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much. The only thing the booksays is to put the tank in until it snaps into place. (Like we didn'ttry that.) Apparently it's a bad design. The seal on mine looks fine.
If I was doing the floor I'd just keep going but I'm trying to do my couches and I don't need a huge puddle on the floor.
8/19/2013 3:13:02 PM • Eureka Atlantis... • Answered on Aug 19, 2013
Where can i get the
you should be able to get the shampoo at wal-mart and any place else they sell the steam cleaners. You do not have to use the eureka shampoo for this unit, however, it is more recommended.
I mean you can use the hoover, and dirt devil shampoo if you can find that, or something generic. Because the machine is mixing the soap for you with the water, anything will work.
As for the owners manual, you can get it here.
11/19/2010 11:50:24 PM • Eureka Atlantis... • Answered on Nov 19, 2010
Lost the owners manual for my Eureka 2595
http://www.eureka.com/service/manuals/73569A.pdf
see if this is it if so print it off I hoe this helps
3/30/2010 9:01:56 PM • Eureka Atlantis... • Answered on Mar 30, 2010
Spray button doesn't function on Eureka Atlantis.No water spray.
should be mechanical, torx screws are easy to remove with a torx screw driver
8/5/2009 1:41:27 AM • Eureka Atlantis... • Answered on Aug 05, 2009
Don't know how to take dirty water canister out
The dirty water container just lifts out, but it can be very stubborn sometimes. You might have to wiggle it a little to loosen, then pull straight up (perpendicular to the floor). Hope this helps!
7/12/2009 9:38:29 PM • Eureka Atlantis... • Answered on Jul 12, 2009
Eureka
Put water in the tank to the fill line. Turn on the unit, and press the spray as you need it. This is a silly question, and should be taken off the board.
5/15/2009 5:27:03 PM • Eureka Atlantis... • Answered on May 15, 2009
Water leaking
The water tanks on this unit have had a very bad history of leaks. Most of the repair people had never heard of this unit, but one did, and had a spare set of tanks. If the unit is still under warranty, it is worth your while to get a replacement unit. Call Eureka, and ask them how to get a replacement unit, especially if you are having more than one issue with the unit (such as leaking, no heat, broken upholstery nozzle, etc.). I had success in sending back the serial number plate and a detailed list of my problems. They sent me a new unit, and I was able to get at least one unit working properly. Some repair men may be able to fix leaks in the seals on the tank. Hold the tank up and if it leaks, well you got your problem! Eureka will not solve your problem, I've discovered they like to let their service depots handle their junk. Most service depots can give you a solution if they are worth their salt. If the service depot can still get tanks, go that direction. If no replacement tanks are available, call Eureka for a whole unit.
2/12/2009 1:24:45 PM • Eureka Atlantis... • Answered on Feb 12, 2009
Eureka atlantis...water won't spray out.
Try taking the upholstery nozzle apart, there are only a couple of screws, and make sure the little tube is attached where it is supposed to be attached. Be careful when you take it apart, and remember how to put it back together. Try running some water in the one end and see if it comes out the other end. I had a problem with the grip switch not working, and ended getting Eureka to send me a whole new unit as it was still under warranty. I honestly tried to fix it myself, but I don't think the design is good enough to be fixed, so replacement is usually the better choice. Again, I say, shame on Eureka for such a bad product. A good appliance service depot should be able to get a new hose for you, but if you have to pay big bucks, I think it is better to try a different brand than Eureka. I'm assuming by your question that the nozzle is the one on the upholstery hose attachment.
12/23/2008 7:12:07 AM • Eureka Atlantis... • Answered on Dec 23, 2008
Need replacement for shampoo bottle on eureka atlantis
I googled Eureka Vacuum Parts and found 1-888-209-8113 svcvacuum.com (USA only)
12/23/2008 7:05:37 AM • Eureka Atlantis... • Answered on Dec 23, 2008
Eureka Atlantis Stopped Working
I would contact eureka for warranty repair. sounds like it there is something wrong with the mechanis of the unit. could be that water is making its way into the motor pump housing and causing damage to the pump
11/29/2008 10:02:25 PM • Eureka Atlantis... • Answered on Nov 29, 2008
Eureka Atlantis 2595A Upright Wet/Dry Vacuum Logo
38 questions posted
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Eureka Vacuums
  • Eureka Vacuums
Most Popular Question
lost owners manual eureka 2595
  • Vacuums
