20 Most Recent Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Questions & Answers
the seat should just lift off or may have to lift swivel seat leaver
ted mobility centre penge
Electric... | Answered on Dec 24, 2019
one ofthe best ways to work it out is the find the motor controller, normally it's a black box located under the seat,
Now remember you have two wires from the batteries B+, B-, two wires to the motor, M+, M- and some smaller wires on maybe a ten connector block that leads to the tiller where the throttle on the handlebars is located.
Hope that helps
Regards
GeWiz.
Electric... | Answered on Aug 20, 2019
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Electric... | Answered on Jul 24, 2019
Flashing twice indicates charger plugged in. Unplug charger and drive.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Electric... | Answered on Jul 08, 2019
according to the manual, there isn't one :>(
https://www.manualslib.com/manual/1035341/Electric-Mobility-Euro-Limited-Rascal-388xl.html
It may have an overload protection switch like the 240 model as shown here
http://www.fixya.com/support/t10001929-rascal_240_scooter_battery_charged
Electric... | Answered on Feb 09, 2019
I need a manual and wiring diagram for a electric mobility mobility electric power scooter wheelchair model chauffeur 230
Electric... | Answered on Dec 05, 2018
The beep code 5 normally means a Brake problem. Check wiring, Scooter Doctor App
Electric... | Answered on Aug 23, 2016
The hub may not accommodate the different tires.
Electric... | Answered on Jul 05, 2016
Check you meter leads. Connected to wrong input.
Electric... | Answered on Jul 03, 2016
No you do not. Just use longer ones to squeeze rims together so you can tighten with the originals.
Put a meter on the Connection to the motor, try to engage the throttle see if any DC voltage is being given. if so does the voltage go up and down?
Your Scooter Manual will tell you what percent grade the scooter will climb. If it is too steep, it may stop because the motor is getting too hot. The Motor will be using more battery power to climb slopes so you may experience a pause, that would be normal.
bats maybe bad or connections bad.
goto my app and look up flash codes. Scooter Doctor App
Go to my app and look up Flash codes for Pride Revo. Scooter Doctor App
Normally this indicates Controller issue, may need to be replaced.
without more to go on this is it. the more information the more concise The answer can be.
After a full night charge with the joystick on, drive it around. If the battery drops off drastically the battery maybe bad. But the same maybe said of the charger, I recommend taking the charger to your local battery shop an have them test it for you.
Electric... | Answered on Apr 12, 2016
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
168 questions posted
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Electric Mobility Health & Beauty
Most Popular Question
electric mobility scooter says charge fu
  • Health & Beauty
