20 Most Recent Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Questions & Answers
Yes the control board is likely the cause if all battery connections are checked and pass
Electric... | Answered on Sep 12, 2018
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
Electric... | Answered on Jul 18, 2018
Hi I would invest in some new batteries ...if they have been in the chair for 3 years without charging them they r no good :::::: when batteries sit 4 a long period a coating forms on. The cells .when this happens they will never charge properly again ..cheers
Electric... | Answered on Mar 03, 2018
McGiver would be proud if you could find the wires attached to the horn button and install a different pushbutton. The real problem will be to find a way of mounting the pushbutton in such a way that it can be accessed without interfering with joystick motion.
Electric... | Answered on Jun 16, 2017
There is a lever on both sides of the chair they are there to make it easy to push the chair without power. both sides need to be in brake mode in order for the chair to operate. If the levers are locked in brake mode then the motor wiring will need to be checked that it is plugged into the controller. A Tech may need to be contacted to help with this.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Electric... | Answered on Mar 03, 2017
There are adjustments that can be made with a programmer, a good technician can set these quickly for you.
Most of these chairs have a clutch release lever near the motors. Move it into free-wheeling and it should roll nicely.
This may soundc crazy but try waving a magnet in front of the joy stick. It has been known to work.
Turn on the Chair and within 10 sec. push the horn twice Beep Beep, this should unlock it.
Scooter Doctor
Electric... | Answered on Jan 18, 2017
How old are the batteries? Even fully charged older batteries can be weaker and not give you as much power to keep the speed at what you are used to. Now a dragging bake can cause you to go slower and also drag the batteries down quicker. Try driving the chair and after awhile check each motor to see if they feel overly warm or hot If one or both feel very warm or hot then I would have the brake or brakes checked If they seen ok I would get the batteries replaced
Electric... | Answered on Sep 18, 2016
You are locked out.
turn on push horn 2 times quickly.
or turn on push joystick handle forward all the way until it beeps then back all the way until it beeps. there you go!
Electric... | Answered on May 15, 2016
If your M41 is more than a few years old it has a Lock Out feature. Try holding the ON button down for 3 or 4 seconds when you go to turn it ON. You should see all the lights come on and stay on. When you see all the lights stay on you can stop holding down the ON/OFF button.
Electric... | Answered on Nov 01, 2015
Your best option to get this specificinformation is properly fro INVACARE
For more information, call them:
01656 776263
Can you order footrest parts some where
Also, look up this website
Invacare Special Adaptations
Electric... | Answered on Sep 13, 2015
It is indicating a left motor fault, which is not good news. This is usually from a motor overheating and burning out, usually from overloading the chair or from driving it on unstable terrain like mud, snow, wet grass or sand. If that is the case, there could be more damage to the electronics once you get the motor replaced too. Replacing the motor is a lot of work and very expensive, so you may want to try to find a replacement chair.
Electric... | Answered on Feb 26, 2015
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
116 questions posted
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Electric Mobility Health & Beauty
Most Popular Question
lights flash right left shut off get
  • Health & Beauty
