20 Most Recent Craftsman Garage Door Opener 1/2 HP Chain Drive Questions & Answers
The learn button is located on the garage door opener unit itself that hangs from the ceiling. If you follow the gray antenna up to the unit you will see a red/orange button on the unit. That is the learn button. When you push that button and amber LED will light up either above or next to the learn button. This indicates that the garage door opener is now ready to learn a new device. Press and hold the button you want programed on the garage door opener remote and release it. The garage door opener will click and the garage door opener light will go off and come back on (if the light bulbs are in working order). The amber LED will go out, repeat if you need to program anything else.
Craftsman Garage... | Answered on Apr 03, 2019
Im assuming the up position works. Try change all batteries and check sensors they can be off by a hair
What exactly is the problem?
Craftsman Garage... | Answered on Oct 08, 2018
disconnect the door and try it with no weight on it .quite likely you have a broken spring .
Craftsman Garage... | Answered on Mar 17, 2016
Possible bad battery. Or there is some type of radio frequency interference coming from somewhere around your house.
contact the person from whom you have bought it.......
Craftsman Garage... | Answered on Nov 20, 2015
This is the one you will need. Best place to buy is from Amazon if you are going to do it yourself.
http://www.amazon.com/Chamberlain-LiftMaster-Craftsman-41C4220A-Sprocket/dp/B006L8CZKI/ref=sr_1_1?ie=UTF8&qid=1424440429&sr=8-1&keywords=craftsman+gear+kit
Craftsman Garage... | Answered on Aug 26, 2015
try adjusting the down force. the force necessary to may it reverse. it may be set too light. increase the down force and see if that helps. usually screw in back of unit. and usually labeled.
Craftsman Garage... | Answered on Jul 25, 2015
There's a gremlin living in your overhead light.....lol. The circuit board in the opener has the timer for the light. There's a component that's beginning to fail on it. Replace the circuit board.
Craftsman Garage... | Answered on Jul 07, 2015
There is an chance you circuit board got a surge. It may need replaced. First try unplugging it for 30 sec and plugging it back in. Garages are generally protected by a gfi plug. Sometime with power outages these trip. Resetting it can also be an easy fix.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_a1f2045feb96cdb4
Craftsman Garage... | Answered on Jun 17, 2015
You might want to restate your question with a little more clarity and details.
Craftsman Garage... | Answered on Jun 08, 2015
Not sure what your door opener is like but if there has been a local strike, or a power surge , it is possible it has been fried. Probably best to let an electrician take a look at it.
Good Luck
Craftsman Garage... | Answered on Jun 02, 2015
put new battery in them and see if they work .ours the button sticks sometimes and just tap it against something to release it
Craftsman Garage... | Answered on Apr 27, 2015
Watch the lights, make sure they do not flicker or blink when you push the button. If they do, then you need to make a better contact by pointing them straighter. If not, then it's not a sensor problem it's probably force. Describe your issue more detail and I can give you a better answer.
Craftsman Garage... | Answered on Mar 03, 2015
Craftsman Garage Door Opener 1/2 HP Chain Drive Logo
39 questions posted
Top Craftsman Building Materials Experts
ray gallant
Jay Plesset
Michel Laprise Sr
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Building Materials
Most Popular Question
sears garage door close only goes about
  • Building Materials
