20 Most Recent
KUERIG Keurig Platinum B70 Brewing System Questions & Answers
Why have you not answered my question?
Because no one here is obliged to answer your question . Respondents choose which questions to answer and because you are a female you don't get special treatment but you seem to think you should.
So go to a feminist site where you will find the totally clueless and incompetent and ask them.
Cup not filling up
There are 3 needles on the underside of the lid and one on the bottom of the kcup holder. Using a thin "uncoated" paper clip, straighten the clip and insert it into the hollow needles and then run a 4oz cup of hot water (NO Kcup}. Repeat until NO more grounds are dispensed. Dave
How to prime
http://www.keurig.com/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx
^^^^ that's the owners manual.
according to it,
LCD Control Center
indicates "PRIME"
and the blue light in
the Water Reservoir
is flashing
Solution:
Completely remove the Water Reservoir and
thoroughly clean (refer to page 14). Ensure
the Water Reservoir is fully filled with water. Return it
to the Brewer and ensure it is seated properly
(refer to page 6).
If you have completed the above procedure two
times and this situation persists, contact Customer
Service at 1.866.901.BREW (2739
Why kuerig vue will not brew complete cup
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
Brews slowly
Run a cup of white vinegar through it.Then a couple cups of clean water,
Kuerig water filter location
Exit tube is the PIN like projection that pierces the top of the Kcup. Cleaning is easy, use a standard paperclip with one end straightened out and stick it as far up the tube as you can to break away and debris that clogged the exit tube. The filter is the small package sitting inside the water reservoir (tank) and it comes out by pulling it upward toward you. This needs to be changed approximately every 3 months, unless you use filtered water and/or distilled water. (which you should do to avoid plugged tubes). If satisfied rate this reply, please.
