20 Most Recent Quakehold! Bear Claw Water Heater Seismic Strap Questions & Answers
We have two Venetial glass urns attached with QH
QuakeHold is made by a company called ReadyAmerica, My dad had the same problem and called them and they told him what to do and it worked. We were more concerned about the Urn, which contained his Mothers ashes than the table and tried everything bit I just knew I was going to break it. He called and told me he got it after talking with ReadyAmerica but it has been a while and I don't remember exactly what he did, but I got their phone number for you: Toll Free 1-800-959-4053. I hope that helps. I am afraid it will leave marks on the wood though, but that can be covered with a Doilee hopefully!
11/10/2009 8:24:47 AM • Quakehold! Bear... • Answered on Nov 10, 2009
Can oly get to one 2x4
If you have drywall, you can use heavy duty drywall anchors. If not, you will have to extend the straps and attach at the same point. If you don't have drywall, you can add another post anywhere if your plate is accessable.
3/31/2009 10:07:12 PM • Quakehold! Bear... • Answered on Mar 31, 2009
Where can I get a Service Manual including error codes, of HITACHI Package unit RUA-30AT3S?
I am not sure they are available to non Hitachi service centres. https://documentation.hitachiaircon.com/glb/en/pac/rua-at3s
3/17/2024 4:06:16 PM • Water Heaters • Answered on Mar 17, 2024
VAILLANT ECOTEC PLUS 831 BOILER , with an error code of F79, which is not in the handbook, its not working at the moment, already had a local plumber out, who didn't know a lot about F79 code
Cannot find the fault code . There are vidoes on u tube saying how to reset thr code By pressing the reset button . If this does not work youcan ccontact vaillent on there web page . I have a mate who works for them i will ask him as well
2/12/2024 9:14:32 PM • Water Heaters • Answered on Feb 12, 2024
2answers
Envirotemp water heater
Do I need to insulate this heater out in the shed? Freezing temperatures
2/6/2024 11:45:03 AM • Water Heaters • Answered on Feb 06, 2024
Remeha avanta plus combi problem
Call a engineer
1/11/2024 7:52:09 PM • Water Heaters • Answered on Jan 11, 2024
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
12/26/2023 4:41:20 PM • Water Heaters • Answered on Dec 26, 2023
How to replace digital thermostat on Amtrol boilermate to a manual thermostat
Where does the tube sensor go
12/23/2023 12:54:29 AM • Water Heaters • Answered on Dec 23, 2023
10 year old Richmond 40 Gallon water heater, cannot move knob to ON/OFF or Pilot. Pilot light is out.
call plumber to replace gas valve, it may cheaper replace water heater. gas valve is not DIY
12/1/2023 6:48:46 PM • Water Heaters • Answered on Dec 01, 2023
My boiler doesn,t always switch off when programe is off
test for sticking relay faulty circuit board or faulty stat
10/28/2023 4:42:20 PM • Water Heaters • Answered on Oct 28, 2023
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock. Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
10/17/2023 2:53:24 PM • Water Heaters • Answered on Oct 17, 2023
3answers
Where on a sunday do I find a GS640YBVIT heater?
I would try their website; www.statewaterheaters.com They should show a list of their service agents.
8/28/2023 6:22:14 PM • Water Heaters • Answered on Aug 28, 2023
How do I bleed the pump? It's running but not circulating water after partially draining the hot water heater.
Domestic Central Heating, Dodge Caravan, well pump or a Pool Heater, or something else. All questions need 'make model (what it is)' as first 3 words. With the exception of the Dodge Caravan, pumps have a small bleed screw. Google make model bleed pump or if it is an above ground well pump make model prime pump This is heavily weighted towards vehicles, but you will get the ideal of the power of Google! https://www.google.com/search?q=%E2%80%8Bmake+model+bleed+water+pump ..
5/17/2023 10:56:35 PM • Water Heaters • Answered on May 17, 2023
Towerchron QE2. Timer set up ok. Room thermostat set 25. Timer lights ok at set timings. Boiler will not come on
Call for Service. The timer is fine, the boiler has failed. I presume it is gas fired, which means that only gas registered service techs can work on it.
4/16/2023 10:15:58 PM • Water Heaters • Answered on Apr 16, 2023
Energy smart water heater has start up failure
Energy smart water heater has start up failure problem so how to resolve
3/26/2023 5:11:27 PM • Water Heaters • Answered on Mar 26, 2023
3answers
Richmond water heater 6g40-36f1 lights then goes
Check the thermocouple and the control box.
3/18/2023 6:55:07 AM • Water Heaters • Answered on Mar 18, 2023
Quakehold! Bear Claw Water Heater Seismic Strap  Logo
2 questions posted
Top Quakehold! Water Heaters Experts
Paul Carew
David Spradling
David Spradling
Are you a Quakehold! Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Quakehold! Water Heaters
Most Popular Question
two venetial glass urns attached qh
  • Water Heaters
