20 Most Recent
Scytek Electronics ASTRA200 Car Alarm 1 Relay 5button Remote Questions & Answers
Can someone get back to me about dashboard symbols and what they mean
I would take to a local car parts to see if they would read the code,, also depending on when the car was purchased and what the PO has done, might be a good time to take it to a qualified garage and get stuff checked out,. Most people do not look at their cars manual nor do they do the manuals service recommendation.
Ignition key not working
sorry !! do you mean key won't turn or key turns but vehicle wont start? key won't turn ;- barel requires re coding ie key or barel worn. key turns but won't start;- depending on year of vehicle and type of remote, have you changed the remote battery, did car start before? some remote casings carry a very small chip inside. The vehicle immobiliser reads this chip to authenticate correct key is being used. This chip is not fixed but sits in a small cavity in the remote case they sometimes fall out if not aware of this you would not notice any difference when reasembling the remote. vehicle will not crank or start
Unlock code for my car radio
Hello, i have seen this problem on my car before when ever the battery got disconected or gone dead. stereo antitheft loc is on and some times if you try to put to many wrong codes in unsucsesfully i had to turn key on for one hour and then the correct code entered.its usually in owners manual under anti-theft stereo loc.they should have wrote the code in there manualy when the car was new.i took mine to a car audio dealer and got the code from a couple of digets that showed up on the radio when he held on to two buttons at the same time and called for the codes that were programed in.this is just a helpfull guide to a related problem i had in a grand prix i bought used and put a new battery in and had no code.i live in louisville ky. and went to a after market dealer on dixie hwy. and it costed about 60 dollars.but since i tryed the wrong code more than three times he had to leave the ignition on for an hour before it would unlock.it worked and i wrote the code down.its usually a 3-4 number code.
Bought this car, dont know how to use the remote start
To add a transmitter on an AstrostartTM Remote Car Starter, follow the
following steps:
• Open the hood
• Turn the key to the ON position
• Push and release the brake pedal
• Cycle the ignition OFF - ON – OFF – ON – OFF. Warning! At the end, the key
should end at OFF. If sequence is made successfully, the parking light will
blink 4 times.
• Push any button on the transmitter to enter in learning mode and the parking
lights will flash 1 time. Repeat the same sequence for any additional
transmitter that needs to be learned in the system.
• Push the brake pedal once
End of programming
