20 Most Recent Uniden FRS1400 2-Way Radio Questions & Answers
2answers
I have a set of
See the instructions beginning on page 4 of this manual.
4/8/2016 4:25:17 PM • Uniden FRS1400... • Answered on Apr 08, 2016
What is the distance that the uniden frs 1400 can transmitt
The FRS radios are 500 mW radios, which is not at all bad. Also, they are ~460 MHz radios which means they are pretty much line-of-sight, So, if you can see it you can talk to it. This doesn't mean you have to be able to see the radio, or person, but the location of the two. Example: I had a dead 2 meter ham radio, it was putting out 15 mW of power, just the exciter no output power transistor working, I was almost home and I could still talk to my friends, the repeater I was talking to was 15 miles away up on a mountain I could see. As soon as I went behind another mountain I could no longer see the mountain with the repeater on it and could no longer talk to my friends. 2meters is ~146 MHz not 460 MHz but they are enough similar that your experience will be the same. If you are in the woods the range will be much shorter, because trees, branches, leaves are closer in wavelength and will tend to absorb your RF power. Out in the open, on a beach, able to see the mountain location your friend is up on, you will probably be able to talk to him/her. In the city you are essentially behind mountains all the time unless you're both on the same straight street.Sorry, there is no definitive answer here the distance you can talk depends on the stuff between you and the other radio. I hope that helps.Oh, one last piece of information - for fun only - If you were in outer space then the distance you could talk could be pretty much calculated by the inverse square law, in other words the distance away you are is the only factor effecting how much power is getting to the other radio and so it can be calculated depending on the output power of the radio, the receiver sensitivity (how much power does it need to receive to hear the other radio), and how far away you are.
4/8/2016 4:01:02 PM • Uniden FRS1400... • Answered on Apr 08, 2016
Frs s14
http://www.uniden.com/two-way-radios/frs1400g/invt/frs1400g Under the "Owners Manual" tab. English only though.
7/28/2014 2:31:54 PM • Uniden FRS1400... • Answered on Jul 28, 2014
I need replacement antennas
you can get them for about $12.00 at walmart
11/2/2011 1:34:18 AM • Uniden FRS1400... • Answered on Nov 02, 2011
I need relpacement antenna for a pair of radios
  • This radio is a standard FRS handheld. Unfortunately these antennas are not replaceable nor do they make them in an aftermarket aspect. If the antenna is no longer working or broke then the radio[s] need to be replaced. No way around it, sorry,.
  • Hope this helps.
11/2/2011 1:08:51 AM • Uniden FRS1400... • Answered on Nov 02, 2011
My unit got run over by a truck , love this model
ebay:
http://cgi.ebay.com/Uniden-FRS1400-14-Channel-Two-Way-Radio-Walkie-Talkie-/380323293923
5/6/2011 12:47:39 PM • Uniden FRS1400... • Answered on May 06, 2011
3answers
Need free codes for a base police scanner
hello there
please try these links they have worked for me
  1. Scanner Frequencies & Codes Free Trunked Fleet ID's for your area (Works with Scancat) Military Base Operations Frequencies ... Get a scanner frequency list by email for your county, ...www.bearcat1.com/free.htm - Cached
  2. Portland Police Scanner | Portland, Oregon Crime & Emergency Dispatcher ... ... use of a Trunk Tracking Scanner and entering the Talkgroup codes listed in the next section. ... your Business Listing for free. Obits / Death Notices ...oregonlive.com/policescanner/...?/policescanner/police_codes.frame - 64k - Cached
  3. Scanner Feeds ... Feeds Police Codes Police 11 Codes General Codes General Acronyms ... They are free. ... Big Bear, California Police Scanner (web-based) Los Angeles Police ...members.shaw.ca/crazykid755/scanner - Cached
2/7/2024 2:07:07 PM • Uniden Radio... • Answered on Feb 07, 2024
Owners manual Uniden Bearcat BC590XLT
The Owner Manual is here Noel
Bearcat BC-890XLT Scanner owner's Manual
repeater-builder.com https://www.repeater-builder.com > uniden > pdf PDF Please read this Operating Guide thoroughly before operating the scanner. Optional Accessories. The following optional accessories for your BC 890XLT are ... 40 pages ..
6/24/2023 5:09:47 PM • Uniden Radio... • Answered on Jun 24, 2023
Uniden Bearcat BC 220XLT Radio Scanner repair/service manual
Some help here, but what you want to be likely not possible. https://www.google.com/search?q=Uniden+Bearcat+BC+220XLT+service+manual ..
5/23/2023 2:41:51 AM • Uniden Radio... • Answered on May 23, 2023
I need a battery for UBC3000 please?
All questions need full 'make model (what it is)' or we guess. I see a number of UBC3000.
Uniden - UBC3000XLT Battery
Complete Battery Source https://www.completebatterysource.com > uniden-ubc... The Uniden - UBC3000XLT Nickel Metal Hydride (NIMH) battery is the perfect replacement battery at a great price! The Uniden - UBC3000XLT battery is ... Capacity: 1100 Length inches: 2.7 US$43.55
3/10/2023 11:22:58 PM • Uniden Radio... • Answered on Mar 10, 2023
D104-M6B WIRING FOR A UNIDEN 880 RADIO DIGRAM
Here is the wiring diagram for connecting a D104-M6B microphone to a Uniden 880 radio:
  • Shield: Connect to pin 1 of the microphone jack on the radio
  • White: Connect to pin 2 of the microphone jack on the radio
  • Red: Connect to pin 3 of the microphone jack on the radio
  • Black: Connect to pin 4 of the microphone jack on the radio
It's important to note that not all Uniden 880 radios are wired the same way. If you're unsure about the wiring on your specific radio, it's best to consult the manual or contact Uniden customer support for assistance.
2/26/2023 4:12:25 AM • Uniden Radio... • Answered on Feb 26, 2023
Uniden UBC370XLT Scanner. Hello, I am looking for a schematic diagram for a UBC370XLT. Does anyone have a copy or know where I might be able to get one please?
Question edited for clarity and add maker + (what it is). Question moved from Misc. You will have to contact Uniden direct. This search query should find it. The CLT model seems better known https://www.google.com/search?q=UBC370XLT+schematic More here including software https://www.google.com/search?q=%22UBC370XLT%22 ..
1/5/2023 2:36:14 AM • Uniden Radio... • Answered on Jan 05, 2023
Uniden 210 XLT. What modification to pick cell phone frequencies
Question edited into english. No modifications. The range is restricted and the calls are encrypted.
12/1/2022 4:28:40 AM • Uniden Radio... • Answered on Dec 01, 2022
How to wire a Superstar 507-5 microphone to a Uniden Washington base unit please?
It should just connect with the plug eBay states. This is a brand new Workman replacement omni-directional CB radio microphone. Features a 5-pin connector and a flexible coiled cord. Wiring:
  • Pin 1 - Audio
  • Pin 2 - Ground
  • Pin 3 - RX
  • Pin 4 - Common
  • Pin 5 - TX
  • Compatible Radios:
  • Cobra 90LTD
  • Cobra 140GTL
  • Cobra 142GTL
  • Cobra 148GTL
  • Cobra 148-F-GTL
  • Cobra 2000GTL
  • Cobra 2010
  • Uniden Washington
  • Uniden Grant XL
  • Uniden Madison
  • https://www.google.com/search?q=connect+Superstar+507-5+microphone+to+a+Uniden+Washington ..
    11/27/2022 9:08:36 PM • Uniden Radio... • Answered on Nov 27, 2022
    I have an Old Uniden BC760XLT scanner been sitting for months..now it Appears by the display To be Scanning,No Audio I've tried the internal/external speaker/recorder jack ..No Audio..any ideas?
    Probably has some leaky capacitors that stop it from working and just shows a display without tuning at all.
    7/6/2022 5:49:23 AM • Uniden Radio... • Answered on Jul 06, 2022
    I just received a Uniden Bearcat handheld scanner model BCD325P2.
    all it can do is in the manual. 2015 made new. all those safety channels frequencies are regulator by FCC.gov and are published here they are, first google hit ,amazing. https://www.radioreference.com/db/browse/stid/12 keep in mind some 800MHz transmitters (gov) are encrypted trunking mode radios, (like police is) in my town text, the HAM band 2meters has full time weather brocast (I have HT and HF here) our RAD does 25mHZ to 900mHz bands all stated in the manual below. page 129 covers the public service bands starting at 758.0125 MH vhf and uhv is line if site comms so that is why there are so many stations. (broad casting) best is try the closet one first. a better antenna , is what to use. what kinds of safety data do you need, not told fire, police , amber alerts, weather, road reports, and lots more what you want not told. but you can find it if you google that, in clear simple text. for sure. by county is best. as it is line of site. police bands are trunked and have are networked sites to overcome line of site issues,. (magic) and is encrypted.(and ******* to hack btw) broadcast is site by site and 20 miles max (aprox) but station power in watts is prime there, and no 2 stations are the same, (rare) set the radio to scan them all , see what it finds.? be patient. or look up what you want googled. https://www.manualslib.com/manual/952528/Uniden-Bcd325p2.html?page=129#manual good luck and happy DX'ing.
    7/2/2022 3:06:23 PM • Uniden Radio... • Answered on Jul 02, 2022
    How to setup a uniden BC75XLT BEARCAT?
    https://www.roadtrucker.com/images/manuals/uniden-bc75xlt-user-manual.pdf
    6/12/2022 11:17:03 PM • Uniden Radio... • Answered on Jun 12, 2022
    Uniden FRS1400 2-Way Radio Logo
    Popular Tags
    7 questions posted
    Top Uniden Radio Communications Experts
    John
    John
    eradiostore
    eradiostore
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
    View Most Popular
    • Uniden Radio Communications
    Most Popular Question
    distance uniden frs 1400 transmitt
    • Radio Communications
