20 Most Recent
Heartbeat Garmin Forerunner 305 Gps Training Watch With Questions & Answers
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
I seem to have lost the alarm (BEEP) on my Garmin 305.
It's a known problem. The little speakers inside get corroded and gradually get quieter and quieter. If you are still within warranty, then send it back to Garmin for a fix. If not, there isn't a home-user fix for this problem, so you'll have to decide if it's worth the $$ to get it fixed. Personally, I decided to get mine fixed.
My garmin forerunner 305 does not identify my
A few things to check: first, you have to moisten the sensors on the inside of the rib band or they won't pick up your heart beat. To do this, put a few drops of water on the ridged areas on both sides. Also, there is a battery in the band which can need replacement. Remove the cover to the battery using a nickel and replace it with a fresh one. If that doesn't work, I have had very good luck with Garmin tech support.
Heart rate monitor not working, changed battery
You need to go in and reset you heart monitor so it is set with the device. Go into accessories; heart rate monitor and reset it. For some reason, it loses it's connection with the monitor and needs to be reset. Especially if you haven't used it for a hwile. My son borrowed my garmin and heart reate monitor. I thought he broke it, but it just needed to be reset.
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ?
I am located in BC Canada
Reg 250-379-2971
[email protected] if you can contact me ?
How can I maintain my pool table at top condition?
In
order to maintain the condition of your table and prolong its lifetime you
should avoid eating above the table, putting drinks of ash trends on the sides
of the table, and generally try not to harm the cloth with the cue. In addition
you can clean and vacuum the table from the outside once a month, this Is what
I'm doing to my table.
What is the price range of a quality foosball table?
Good quality and long-lasting table start at
about $600. In this case, like in many others, the more you pay, the better
quality you will get. Make sure that you're buying a known brand and compare
prices first, before you buy. It is also recommended to read some reviews about
a table or tables that you like.
How to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
I'm in my 50's, can I start playing table tennis?
Definitely! You should know that Table tennis is asport for all ages, and it is never too late to get started. You should know that in the year 2008, Olympic table tennis canbe called the Veteran Year as 38 year old
Gao Jun and34 year old
**** Chendirectly qualified for the 2008 Beijing Olympic Games on the women's side. Andon the men's side, 45 year old
David Zhuangwon the right to attend the Olympic Games as the USA' sole male representative.
