20 Most Recent
Toro 51599 Electric Blower 12 Amp Questions & Answers
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Where can i get a replacement motor for a toro model 51599 blower
Toro motors are not available a reasonable price. If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may still be able to use your motor by replacing the carbon brushes and or cleaning the commutator. Hope this helps.
Problem is my hardly used Toro Blower Vac is
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
My toro ultra 51599 stopped
It is very common for the bottom cover to not push in the safety button and render the machine "dead" a simple fix. you can get a new cover through a shop like www.arcolawn.com
cheers
Joe
I have a Toro 51598 electric leaf blower. Last
These machines are considered "disposable" items and most service centers won't even repair them, saying that it is not "cost effective." I have never come across a parts list for one other than maybe the plastic housing on them (they may exist), but costwise you may be better off getting another tool unless the Toro is still under warranty.
12/13/2010 12:09:38 AM •
Toro 51599...
Answered
on Dec 13, 2010
Can't figure out how to make is vacumn instead of
You open up the bottom fan area (the air intake) where it is sucking air in to use as a blower. You remove the long blower tube and insert your vaccum collection bag on the machine's outlet port. You then install your vacuum tube on the bottom where the fan is: (inlet port). Now as it sucks in air (and leaves) and blows it out (into the bag instead of the air); you have a vaccum, not a blower. Here is your instruction manual:
Click on operator manual on the left side of the chart.
http://tinyurl.com/3ypqxsa
11/22/2010 12:14:39 AM •
Toro 51599...
Answered
on Nov 22, 2010
