20 Most Recent
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Questions & Answers
Why is Yardworks riding mower battery draining
First make sure your battery is good. The charging systems on these mowers is not sufficient to charge a completely dead battery. If the battery is good, you have an electrical drain somewhere on the unit. Tracking it down will take a multi-meter and a little time.
I have a Poulan (Weedeater)
There should be a brake stop on the spindle itself. When the belt is released, the brake should contact the spindle and stop the blade. If this is missing or not working, you could see the problem you are having.
Black smoke and noise when engaging deck.
Depends on where the black smoke is coming from. If it's coming from the deck then it's a belt issue, if it's coming from the engine then you have a carburetor issue. Most likely the governor isn't set up correctly or the choke isn't all the way off.
Runs, wont move
Hi, the is a blade belt AND a drive belt on these models. chances are your drive belt is broken or just off the pulleys. if you take the rear plate off the mower you will be able to see the drive belt directly under the seat.
Will not go into reverse or neutral
it sounds like the transmission through shaft is frozen in the housing? if it still pulls in foreward gear and will not shift to any other gear you will probably need to tear down the transmission or replace it. if not mechanically inclined will have to go to a shop
How to replace solenoid in Craftsman 917.270930
well first remove neg battery terminal. then remove the battery cable nuts on the solenoid. then remove the smaller wires. finally remove bolts holding the solenoid. reverse order to install
