20 Most Recent Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Questions & Answers
Battery won't hold charge, but mower will start using a jump pack. After running it , when you cut it off it just clicks when you turn the key to crank it.
check all the connections for a loose or corroded joint. the stater could also be bad. check to see if it is charging when running with a meter.
5/26/2016 4:40:15 PM • Swisher 44-Inch... • Answered on May 26, 2016
Getting the blades off any suggestions
Yes, if at all possible , try to get an impact wrench, air or electric will do. makes the job of removing the blades a lot easier.
8/29/2015 8:21:45 PM • Swisher 44-Inch... • Answered on Aug 29, 2015
I have an 11.5 hp Briggs It will start 2-3 times and then nothing NO spark. plug is new, I suspect the coil, what do you think?
use 2 thicknesses of a match book,or .012,,pull the black wire off the coil and start it,if it runs then a safety switch is bad
6/21/2015 4:07:37 PM • Swisher 44-Inch... • Answered on Jun 21, 2015
I am having trouble getting my trailcutter to stay cranked. It is not priming gas to the engine. I have replaced the fuel filter and fuel pump, and checked the hoses for any obstructions. Do you have
Try removing the anti backfire valve on the bottom of the carb and cleaning it. They sometimes stick closed due to ethanol gum. Mace sure you hear a click when you turn the switch on. The solenoid which operates the AB Valve could be bad or have a broken wire.
1/3/2015 4:51:10 AM • Swisher 44-Inch... • Answered on Jan 03, 2015
Where to buy bearings
There should be a number on the bearing itself. Take that to your local auto parts and they can cross it over to any number of manufactures.
8/8/2014 6:49:23 PM • Swisher 44-Inch... • Answered on Aug 08, 2014
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
7/1/2014 11:48:25 AM • Swisher 44-Inch... • Answered on Jul 01, 2014
0answers
What causes excessive vibration in 11.5 HP Swisher Trailcutter after hitting a stump?
The most likely cause is a bent blade. If the blades are not reasonably straight and balanced it will cause excessive vibration. I suggest addressing this asap. The excess vibration can cause more serious problems if not fixed.
5/24/2014 1:29:56 PM • Swisher 44-Inch... • Answered on May 24, 2014
The muffler is getting very hot and turning red and losing power.
sounds like you have valve trouble
11/9/2013 4:23:04 PM • Swisher 44-Inch... • Answered on Nov 09, 2013
Drive belt length for 44inch swisher rough cut mower
it shows a 50in belt
11/9/2013 4:13:29 PM • Swisher 44-Inch... • Answered on Nov 09, 2013
44 swisher
THAY SHOULD MOOVE THE ONE THAT WONT MOVE NEEDS BEARINGS
11/9/2013 2:14:17 AM • Swisher 44-Inch... • Answered on Nov 09, 2013
0answers
0answers
0answers
3answers
Just purchased the RTB12544-CA. There are no
I wish I had an answer. I just bought a Swisher Trail Cutter this weekend (3-27) and have the exact same question. Where does the console assembly mount? On the mower deck? The blades have to be "engaged" in order to operate. I do not have an electric start....it is a pull start....like a simple lawn mower.
8/2/2013 12:02:08 PM • Swisher 44-Inch... • Answered on Aug 02, 2013
Swisher 44-Inch 12.5 HP Trailcutter #RTB12544 Logo
42 questions posted
Top Swisher Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
View Most Popular
Swisher Garden
  • Swisher Garden
Most Popular Question
v belt replacement
  • Garden
